Who's Online Now
3 registered members (Stevejo, 2 invisible), 119 guests, and 4 spiders.
Previous Thread
Next Thread
Print Thread
Page 2 of 2 1 2
Re: naytag refrigerator not making ice [Re: caribbeankline] #951047
01/21/19 04:09 AM
01/21/19 04:09 AM
Ont Canada
jeff1  Offline
Ont Canada
Quote
Checked for 120v at L and N. could not get a reading
Check the thermal fuse in the wire between the cabinet and ice maker ( black slug ). Continuity is good, no continuity is open or bad.
Quote
is there a diagram for the freezer plug to tell me the test points?
[Linked Image]
GR/YL is ground.
WH is white or neutral.
BL RD is line.
TN is for the fill valve.
Re: naytag refrigerator not making ice [Re: caribbeankline] #951054
01/21/19 07:18 AM
01/21/19 07:18 AM
michigan, usa
caribbeankline Offline OP
michigan, usa
i checked the four wire harness between ice maker and cabinet for continuity all four were good
Ever since i was a little guy, I have had to take things apart to see what made them work, and usually I was able to put them back together.
Re: naytag refrigerator not making ice [Re: caribbeankline] #951194
01/23/19 02:30 AM
01/23/19 02:30 AM
michigan, usa
michigan, usa
the four wire harness tested good for continuity ,,,,
the four wire plug ,in the freezer is mounted vertical
but different from diagram
from top to bottom
green
tan
white
red
checked for ac power
red to green
and white to red
measured no power
thanks.please let me know
Re: naytag refrigerator not making ice [Re: caribbeankline] #951350
01/25/19 07:07 PM
01/25/19 07:07 PM
Ont Canada
jeff1  Offline
Ont Canada
Broken wire in the cabinet is likely then if we are not getting any power ( 110-120 volts AC ) readings from Line to Neutral or from Line to ground frown
Re: naytag refrigerator not making ice [Re: jeff1] #951382
01/26/19 05:42 PM
01/26/19 05:42 PM
michigan, usa
michigan, usa
would it be possible to hotwire it? do you have a full wiring diagram, so i can try to trace it down? thanks
Re: naytag refrigerator not making ice [Re: caribbeankline] #951447
01/28/19 01:12 PM
01/28/19 01:12 PM
Ont Canada
jeff1  Offline
Ont Canada
I found a diagram linked here.
I use to drill a hole out the back and try to run a new wire up into the freezer when we suspected a broken or open wire in the cabinet.
Re: naytag refrigerator not making ice [Re: jeff1] #951856
02/06/19 04:56 PM
02/06/19 04:56 PM
michigan, usa
michigan, usa
Thanks for the link, could you possibly draw a
hand sketch to simplify it for me though, which wires am I replacing
Re: naytag refrigerator not making ice [Re: caribbeankline] #951861
02/06/19 07:27 PM
02/06/19 07:27 PM
Ont Canada
jeff1  Offline
Ont Canada
Quote
Is this correct?
Red/black to white, 0 volts.
Red/black to green/yellow 0 volts.
Re: naytag refrigerator not making ice [Re: caribbeankline] #952028
02/11/19 10:03 PM
02/11/19 10:03 PM
michigan, usa
michigan, usa
the four pin connector color code seems to vary from the diagram
from top to bottom
green/wt
tan
wt
red
there is not a red/blk and the wire color are in a different order from the above diagram
from red to white =0 volts
from red to grn/wt = 0 volts
thanks
Re: naytag refrigerator not making ice [Re: caribbeankline] #952044
02/12/19 03:26 AM
02/12/19 03:26 AM
Ont Canada
jeff1  Offline
Ont Canada
Quote
No there is not, what this is the refrigerator side of the wire plug has line being black, this changes to red on the ice maker side of the harness plug.
Quote
This would indicate the line is missing not the neutral. I would just run a single wire down to the power side of the cord plug and other end hook up in the freezer to the red power wire on the ice maker wire harness.
Diagram linked here.
On the diagram it is L1 you would hook into on the power cord.
Page 2 of 2 1 2
(Release build 20180918)
Page Time: 0.021s Queries: 15 (0.003s) Memory: 3.1958 MB (Peak: 3.4412 MB) Zlib disabled. Server Time: 2019-02-20 21:20:04 UTC
