Who's Online Now
2 registered members (debodun, 1 invisible), 113 guests, and 4 spiders.
Previous Thread
Next Thread
Print Thread
Page 1 of 2 1 2
naytag refrigerator not making ice #950655
01/14/19 08:13 PM
01/14/19 08:13 PM
michigan, usa
caribbeankline Offline OP
michigan, usa
Hello ,
I dont know if jeff or anyon,e can help me, my maytag fridge quit making ice a few days ago, it was making a lot of noises, ie. .clicking and stuff..
I am thinking the gears in the ice maker my be junk,but dont know how to trouble shoot this to be sure......
Jeff has helped me alot over many years, is he still around?
I have had the fridge for about nine years(aguess?) bought it used but replaced the ice maker when i bought it.
naytag
model msd2652kew
ser 50366871Jg
the water works great to the door, the water to the door was a little slow, but recently changed the filter , and now it works great.
thanks
Ever since i was a little guy, I have had to take things apart to see what made them work, and usually I was able to put them back together.
Re: naytag refrigerator not making ice [Re: caribbeankline] #950678
01/15/19 03:33 AM
01/15/19 03:33 AM
Ont Canada
jeff1  Offline
Ont Canada
Quote
Low or slow water pressure can cause the fill spout to freezer over stopping the ice maker from working....please check for that.
Quote
Other than visually watching the ice maker cycle and listening for those noise there may not be much else you can test for. Maybe watch, is it getting stuck, binding, ect.
[Linked Image]
LINK> Refrigerator icemaker assembly, modular style
Re: naytag refrigerator not making ice [Re: caribbeankline] #950798
01/17/19 01:51 AM
01/17/19 01:51 AM
michigan, usa
michigan, usa
the water fill tube was not frozen shut, so i purchased a new icemaker, i installed it almost nine hours ago, it has not even filled with water yet,I was hoping it had to get cold first......the arm is in the down position....not sure where to look now
thanks
Re: naytag refrigerator not making ice [Re: caribbeankline] #950803
01/17/19 03:33 AM
01/17/19 03:33 AM
Ont Canada
jeff1  Offline
Ont Canada
It does have to get cold first....9 hours should be more than enough time. Has the freezer temp been measured with a thermometer?
Is the ice maker running? Might be a good idea to leave the arm up over night and in the morning put the ice makers arm down to see if it runs. *Might* have to tape the door switch down so you can view with the door open.
Re: naytag refrigerator not making ice [Re: caribbeankline] #950812
01/17/19 02:57 PM
01/17/19 02:57 PM
michigan, usa
michigan, usa
freezer temp is 5 degrees F
Re: naytag refrigerator not making ice [Re: caribbeankline] #950813
01/17/19 02:59 PM
01/17/19 02:59 PM
michigan, usa
michigan, usa
if i leave the arm up overnight as suggested, and tape the door switch .
when i put the arm down in the morning, should it immediately fill with water? or what should i see
Re: naytag refrigerator not making ice [Re: caribbeankline] #950875
01/18/19 03:18 AM
01/18/19 03:18 AM
Ont Canada
jeff1  Offline
Ont Canada
Quote
A little warm, 0ºF is better. Most of these ice makers want the freezer temp to get below 15ºF to close the thermostat inside the ice maker, so you should be ok.
Quote
Nope, that is at the end of the ice maker cycle. Should start up and run turning the feller arm, raising and lowering the wand arm ice level arm and the last 6-9 seconds is fill.
Re: naytag refrigerator not making ice [Re: caribbeankline] #950944
01/19/19 03:32 PM
01/19/19 03:32 PM
michigan, usa
michigan, usa
Well , I put the arm in the up position overnight, the next day I opened the door,taped the door switch, put the arm down and watched it for a solid 5 minutes, Nothing moved, the arm did not move , the fingers did not seem to move......
where do i go now, I assume i need to check for power? but where and what volts., or do i need to open the "gear" area?
thanks for your help
Re: naytag refrigerator not making ice [Re: caribbeankline] #950977
01/20/19 04:40 AM
01/20/19 04:40 AM
Ont Canada
jeff1  Offline
Ont Canada
Quote
Yes, remove front cover.
Meter test points...
LINK> http://www.applianceaid.com/icemaker-module.php
If needed:
[Linked Image]
LINK> Digital Multimeter is an economical...ical & temperature measurement needs
Re: naytag refrigerator not making ice [Re: caribbeankline] #951005
01/20/19 05:31 PM
01/20/19 05:31 PM
michigan, usa
michigan, usa
Checked for 120v at L and N. could not get a reading,tried putting a extension wire in the holes to be sure.still nothing.(my mulitmeter leads are 1/2 long...
pulled the new icemaker back out, checked the (4) wire harness unplugged both ends for continuity (was good)....
tried checking for voltage at the 4 wire plug in the freezer(went with red and green as ground)just a guess. Nothing
not sure if i should get constant voltage at that point (as the ice maker is out of the circuit)
is there a diagram for the freezer plug to tell me the test points?
Any suggestions?
thanks
Page 1 of 2 1 2
(Release build 20180918)
Page Time: 0.024s Queries: 15 (0.009s) Memory: 3.1972 MB (Peak: 3.4412 MB) Zlib disabled. Server Time: 2019-02-20 21:54:49 UTC
