Who's Online Now
Previous Thread
Next Thread
Print Thread
Page 1 of 4 1 2 3 4
Car Barely Passed Inspection #948576
12/06/18 03:17 PM
12/06/18 03:17 PM
Upstate New York near Albany
D
debodun Offline OP
debodun  Offline OP
D
Everything was good in my 2002 Honda Civic LX sedan except the tires and front brakes. The mechanic said I have tread depth of 3/32 on the right front and rear tires and 4/32 on the left ones. He also recommended that I have the front brakes serviced since there was 2 mm pad thickness on the front left brake (I assume the other was okay or he would have mentioned it). I just wanted advice on where I should bring the car for brake service (dealership or a local mom & pop garage) and what would be the best deal (i.e. don't pay over $?) on tires since I will probably only keep the car another 2 years. My tire size is P185 70 R14.
Re: Car Barely Passed Inspection [Re: debodun] #948577
12/06/18 03:27 PM
12/06/18 03:27 PM
The Indianhead's Left Nostril....
CabinConnection  Offline
Similar older car tire needs here. Went with Douglas All-Season from Wal-Mart. IIRC they were about $40 each.
On the brakes, assuming they have audible wear indicators, I'd leave 'em until they make noise. If no wear indicator, it's not too expensive to just put in new pads (no rotors). Check around for pricing on this. OFTEN dealers are less expensive, or have a special going. Loss leader for them to get you into the facility, then they upsell. DON'T let them upsell.
Re: Car Barely Passed Inspection [Re: debodun] #948587
12/06/18 04:37 PM
12/06/18 04:37 PM
D
debodun Offline OP
debodun  Offline OP
D
Thanks for the advice on the tires, CC. With so many tire places offering so many tires and so many prices, I get confused.
Re: Car Barely Passed Inspection [Re: debodun] #948590
12/06/18 04:44 PM
12/06/18 04:44 PM
SW Michigan
mommapup.  Offline
SW Michigan
We've bought tires from WalMart for years. Pretty good deal. Free rotation and hazard repairs.
Re: Car Barely Passed Inspection [Re: CabinConnection] #948592
12/06/18 05:08 PM
12/06/18 05:08 PM
Houston TX
S
Suenmark98 Offline
Suenmark98  Offline
S
Houston TX
CC -
Your "only replace pads" recommendation sounds like a fine idea, given it's not obvious the short & long term cost to cut rotors may not balance against the minimal or no increased pad wear caused by not turning rotors
But I've always wondered if places will do just pads - or will they claim they have to do a whole workover due to claims of liability?
Anybody have much experience getting only pads done?
Mark
______________________________________________________________
Every day is good, and some are even BETTER !!!!
Re: Car Barely Passed Inspection [Re: mommapup.] #948593
12/06/18 05:09 PM
12/06/18 05:09 PM
Houston TX
S
Suenmark98 Offline
Suenmark98  Offline
S
Houston TX
I second the motion - Have used Walmart / Sams for tires for years and had great products, good values, and good service.
Mark
Re: Car Barely Passed Inspection [Re: Suenmark98] #948598
12/06/18 06:52 PM
12/06/18 06:52 PM
SW Michigan
mommapup.  Offline
SW Michigan
Most places will do a "pad slap", after an inspection of rotors, calipers, wheel bearings.
Also... many rotors can't be turned because there just isn't enough meat on them. Mostly on smaller low-end cars.
Re: Car Barely Passed Inspection [Re: debodun] #948602
12/06/18 07:39 PM
12/06/18 07:39 PM
Bristol,ny
code_ceis  Offline
Bristol,ny
Check your local BOCES school they may have an Auto shop they will do work you buy the parts.
AND pizza. grin
Re: Car Barely Passed Inspection [Re: Suenmark98] #948603
12/06/18 07:42 PM
12/06/18 07:42 PM
A little. Some places refuse to not change the rotors, but unless they are worn beyond minimum thickness, and/or have excessively deep grooves in them and/or are warped (pulsating pedal), there is often no need. Especially on an older "beater". New pads will seat just fine on older scratched rotors.
As a related aside, I roll in new pads on my bikes on a regular basis.
Independent car repair places are more likely to do just a pad swap.
Re: Car Barely Passed Inspection [Re: debodun] #948629
12/07/18 01:31 PM
12/07/18 01:31 PM
Cape Spencer, New Brunswick, C...
JasonB  Offline
I routinely get 2-3 pad pairs per rotor set. Any place that won't do so, when the rotor condition is acceptable (thickness, wear state) looses my business.
Page 1 of 4 1 2 3 4
(Release build 20180918)
Page Time: 4.384s Queries: 15 (4.332s) Memory: 2.8879 MB (Peak: 4.1862 MB) Zlib disabled. Server Time: 2018-12-18 12:54:11 UTC
