Who's Online Now
0 registered members (), 133 guests, and 1 spider.
Previous Thread
Next Thread
Print Thread
Switch Ground #947549
11/13/18 06:05 PM
11/13/18 06:05 PM
South Carolina
A
allbutnuts Offline OP
A
South Carolina
Renovation job. Old switches don't have a ground terminal.
Purchased new 20 amp switches for 12ga wire that was pulled... commercial.
New switches have a ground terminal.
Does a ground wire have to be connected to this terminal?
Re: Switch Ground [Re: allbutnuts] #947551
11/13/18 06:09 PM
11/13/18 06:09 PM
Bristol,ny
code_ceis  Offline
Bristol,ny
Yes
404.9 Provisions for General-Use Snap Switches.
(A) Faceplates. Faceplates provided for snap switches
mounted in boxes and other enclosures shall be installed so
as to completely cover the opening and, where the switch is
flush mounted, seat against the finished surface.
(B) Grounding. Snap switches, including dimmer and similar control switches, shall be connected to an equipment
grounding conductor and shall provide a means to connect
metal faceplates to the equipment grounding conductor,
whether or not a metal faceplate is installed
Re: Switch Ground [Re: allbutnuts] #947553
11/13/18 06:15 PM
11/13/18 06:15 PM
South Carolina
A
A
South Carolina
OK. Thanks!
Re: Switch Ground [Re: allbutnuts] #947564
11/13/18 09:10 PM
11/13/18 09:10 PM
Central Pennsylvania
A
AnthraciteSparky Offline
A
If it's a renovation job then you should have ground wire pulled, correct ?
Re: Switch Ground [Re: AnthraciteSparky] #947565
11/13/18 09:57 PM
11/13/18 09:57 PM
South Carolina
A
A
South Carolina
Yes & no. Most of the wiring has been run in conduit (solid single conductor), so not typical romex situation. Hoping to only have to run one ground now. Was originally trying to figure out a way not to have to run a ground to switches only.... since old switches didn't have ground terminal.
Re: Switch Ground [Re: allbutnuts] #947572
11/13/18 10:37 PM
11/13/18 10:37 PM
Bristol,ny
code_ceis  Offline
Bristol,ny
Metal conduit and metal boxes?
Re: Switch Ground [Re: allbutnuts] #947574
11/13/18 10:41 PM
11/13/18 10:41 PM
South Carolina
A
A
South Carolina
Most. The ones in question, yes.
Re: Switch Ground [Re: allbutnuts] #947576
11/13/18 10:57 PM
11/13/18 10:57 PM
Bristol,ny
code_ceis  Offline
Bristol,ny
That can be the ground path in some cases.
Re: Switch Ground [Re: allbutnuts] #947578
11/13/18 11:18 PM
11/13/18 11:18 PM
South Carolina
A
A
South Carolina
OK. Good to know for future reference. Pulling wire now...
Re: Switch Ground [Re: code_ceis] #947646
11/14/18 08:43 PM
11/14/18 08:43 PM
A
A
Please recheck that, as its no longer a legal ground path, according to my three inspectors. Might be a regional thing.
(Release build 20180918)
Page Time: 0.021s Queries: 14 (0.010s) Memory: 2.8701 MB (Peak: 3.0155 MB) Zlib disabled. Server Time: 2018-12-18 13:31:26 UTC
