Who's Online Now
Previous Thread
Next Thread
Print Thread
Switch power source changed from slab to attic #947546
11/13/18 05:38 PM
11/13/18 05:38 PM
South Carolina
A
allbutnuts Offline OP
A
South Carolina
Need help getting my head wrapped around this....
I have removed a partition wall and found that power supplying some switches is coming from slab conduit. I need to remove the conduit and abandon the circuit in the slab.
As a result, I will need to supply switches with power from the attic.
I know I need to drop hot wires down to the switches to power them, but I'm not clear what I need to do about neutrals & grounds.
I'm reasonably certain that I need to drop another ground down to the switch.
But what about a neutral? It won't be connected to the switch anyway so why does it even matter if there is a neutral on a switch circuit?
Sure, when I abandon the slab wiring I'll need to disconnect the existing neutral... just don't understand what the purpose was in the first place..... relative to a switch.
Can someone help me think this through?
Re: Switch power source changed from slab to attic [Re: allbutnuts] #947548
11/13/18 06:05 PM
11/13/18 06:05 PM
Bristol,ny
code_ceis  Offline
Bristol,ny
The code requires a grounded conductor (neutral) at all switch boxes now.
Many dimmers and occupancy sensors require a neutral to operate.
The ground is required at all boxes.
The local energy code may require occupancy sensors.
Consult the local AHJ.
You should remove all unused wiring also.
Re: Switch power source changed from slab to attic [Re: allbutnuts] #947552
11/13/18 06:09 PM
11/13/18 06:09 PM
South Carolina
A
A
South Carolina
OK. Thanks again.
(Release build 20180918)
Page Time: 0.013s Queries: 14 (0.008s) Memory: 2.8025 MB (Peak: 2.8895 MB) Zlib disabled. Server Time: 2018-12-18 12:48:24 UTC
