7 registered (kickintile, Able_Dog, 5 invisible), 49 Guests and 2 Spiders online.
Page 3 of 3 < 1 2 3
New Reply
#721506 - 07/12/12 01:35 PM Re: Straightening of Miter Saw Fence [Re: grizzly]
Able_Dog Online   content
Loc: N Georgia
Originally Posted By: grizzly
Notice the opening in the center of the fence, you can't put anything across that, it has to remain open.
...i'm sure he thought common sense would be initiated.
To correct the condition a piece of steel or aluminum would have to transverse that opening since the problem is in the semi-circular piece (behind the opening) that connects the two fences which are not in alignment with each other.
Top Reply Quote Quick Reply Quick Quote
#721542 - 07/12/12 05:21 PM Re: Straightening of Miter Saw Fence [Re: Able_Dog]
Clint_Robbins Offline
Loc: Akron, OH
"clamping the center to my cast iron table saw table"
Table saw may be a big heat sink and prevent you from heating it enough?
The shims under the ends of the fence and a piece of Bakelite, or something similar, between the clamp and fence should work.
#721543 - 07/12/12 05:42 PM Re: Straightening of Miter Saw Fence [Re: Clint_Robbins]
Loc: N Georgia
I'm sure I was "preaching to the choir" with the heatsink.
#721816 - 07/16/12 06:13 AM Re: Straightening of Miter Saw Fence [Re: Clint_Robbins]
JasonB Offline
` Sharp Shooter`
Loc: Cape Spencer, New Brunswick, C...
I'd go with kickintile's suggestion of using a TS table and wet/dry paper as a lapping surface and simply sand the fence to true. This is very similar to how I dress waterstones for sharpening knives when they wear hollow. Some careful work at the end will ensure things end up flat and square.
I've found using wet/dry SiC paper with water, it will adhere to the ts table without tape or adhesives, just capillary action from the water.
J
er, somethin'....
Page 3 of 3 < 1 2 3
Quick Reply:
HTML is disabled
UBBCode is disabled
