1 registered (1 invisible), 154 Guests and 2 Spiders online.
#9528 - 10/18/01 12:54 AM Thermopile vs. thermocouple
I think I got ripped off by the plumber -
He came today and fixed my heater which had the problem of the pilot going out when the heat was turned on. He told me it was the thermocouple, I thought, but then he wrote "thermopile" on the service sheet. I read here somewhere that a thermocouple goes for ten dollars - it took him 20 minutes and then charged $287!!!! If I had know, I would have done it myself.
#9529 - 10/18/01 04:10 AM Re: Thermopile vs. thermocouple
A thermocouple is one single unit that produces about 40 milivolts or so a thermopile is many thermocouples tied in series which produces about 500 to 750 milivolts, it's like putting batteries in series.
I have not purchased a thermopile for some time but I can't believe they would be over $20.
Is that all he did?
#9530 - 10/18/01 04:44 PM Re: Thermopile vs. thermocouple
You are correct in your description of the difference between thermocouple and thermopile, and less than $20 is usual for them. You would want to ask the plumber how he arrived at the billing charge. Some plumbers have very high regular hourly rates, even higher off-hour and holiday rates, and may be worth their expertise. That proof will come in time.
Harold Kestenholz
#9531 - 10/18/01 11:00 PM Re: Thermopile vs. thermocouple
Thank you both for replying. It does sound like a thermocouple - and I have the old one to prove it (just two wires leading from a black small plasic piece on one side and the other side has one wire that leads to a single solid cylinder that sits at on the pilot light.
The Plumber I used if from a company that has fixed rates, no hourly rates. The thermocouple is clearly designated as $99. I can't believe, even if it is a thermopile, that it would be much more than that.
Thank you both again for replying
