2 registered (rfm3, xmy556a), 209 Guests and 3 Spiders online.
#945653 - 10/02/18 08:07 PM Thermostat Losing Clock Setting
wirehead43 Offline
Loc: SC
Just installed a Honeywell #RTH6580WF1001/U1 programmable WiFi thermostat purchased at Lowes. After installing the "C-wire" for power it seems to be working fine except for one thing. When power is interrupted, even momentarily as during a glitch, the clock setting reverts back to 0:00 PM. I've not entered a program schedule yet as there's really no point so long as it keeps losing the clock setting. Neither have I setup the WiFi. I've checked the specs. but can't find anywhere it says the TStat does or does not have memory retention. Next step is to try and call Honeywell. Wondering if that's the way it should work or do I just have a bad TStat? Thanks for any help.
#945654 - 10/02/18 08:09 PM Re: Thermostat Losing Clock Setting [Re: wirehead43]
Backup battery good and installed correctly?
#945678 - 10/03/18 11:54 AM Re: Thermostat Losing Clock Setting [Re: wirehead43]
wirehead43 Offline
Loc: SC
This thermostat has no battery. I did learn it has a "super capacitor" that's intended to keep the clock running when power fails - but only for a minute or so. I spoke with Honeywell this morning and was told most all WiFi TStats do not have battery backup and will lose the clock when power fails. However, they will retain schedule settings. The clock and day of week must be manually reset. However, if you have an internet connection and if the TStat is able to reconnect with the web after the power fail, it will re-start the clock and resume the schedule. That's too many IF's for me - a poor design. I'm taking this one back to exchange for a programmable TStat with battery backup but which won't have WiFi. Reliability is more important than WiFi connectivity.
#945680 - 10/03/18 12:18 PM Re: Thermostat Losing Clock Setting [Re: wirehead43]
DANG! I would have sworn mine had batteries! (Same model as you site in this thread.) So I just went and looked...
NOPE! None there! blush
But we have power outages frequently, often lasting for hours.
NEVER have I lost the settings on mine...
BTW, I love that particular 'stat. To the point where I've installed it in a number of accounts that I oversee. I get notified of power outages and excessive (hot or cold) temps via the 'Net. Plus I can remotely change the HVAC settings w/ my cell - REALLY nice when I've been away for an extended period of time and want to bring the temp back up (or down).
#945693 - 10/03/18 06:10 PM Re: Thermostat Losing Clock Setting [Re: CabinConnection]
twoshoes Offline
Loc: PA
I believe this is how it is supposed to work. Once the wifi is set up and a connection with Honeywell is established, as soon as Honeywell loses connectivity to the thermostat the online program shows the down condition. When power is restored and the thermostat reconnects to Honeywell they clear the down error message from the program and resent the correct time to the thermostat. I have never needed to adjust the clock for power outages or daylight saving time changes on either of my thermostats setup this way.
Tom
#945864 - 10/08/18 01:04 PM Re: Thermostat Losing Clock Setting [Re: wirehead43]
wirehead43 Offline
Loc: SC
I'm installing this thermostat in a church where maintaining the heat/cool schedule is very important. Since our internet router isn't strong enough to reach the thermostat, we've had to install a WiFi extender. With that said, I'm not convinced our internet connection is reliable enough to trust the time getting reset through the WiFi. We only wanted the WiFi connection for remote monitoring. Don't understand why Honeywell chose not to use a battery to maintain the clock. Maybe to save a buck or two.
