2 registered (2 invisible), 220 Guests and 5 Spiders online.
#944742 - 09/13/18 10:47 PM Re: No drain [Re: eddie2004]
Disconnecting the wire plug allows access to the wire ends.
Yes you will need a loop of wire with the ends bared to bypass the lid switch.
http://www.applianceaid.com/direct-drive-washer-lid-switch-bypass.php
#944770 - 09/14/18 03:08 PM Re: No drain [Re: jeff1]
eddie2004 Offline
Loc: los angeles ca.
Turns out lid is not depressing switch enough to close circuit, so by putting a little heavy on lid switch is then closed which allows for spinning & draining.
#944780 - 09/14/18 09:38 PM Re: No drain [Re: eddie2004]
That is a bad switch....often the switch body cracks or starts to separate a little and the plunger has trouble pushing down to activate the switch.
Good job so far.
