3 registered (code_ceis, 2 invisible), 33 Guests and 4 Spiders online.
#936975 - 04/13/18 06:59 PM Microwave is suddenly extra noisy and not cooking
johninpa Offline
Samsung MW4351 from 1997. After some research, I took the diode out and tested it with a 9v battery. It's continuous in both directions, ie not a diode any more, so I'd like to replace it as step one. Can I replace it with any microwave diode that fits? I can't find any parts info on my particular model number.
Thanks
John
PS Removed diode, square cross section, is labeled HVR-1X 3 and SK 6009. Shrunk on insulation says VERSAFIT (9.0/4.5) CSA.
Edited by johninpa (04/13/18 07:03 PM)
#936985 - 04/13/18 11:45 PM Re: Microwave is suddenly extra noisy and not cooking [Re: johninpa]
MW4351
Please recheck, I could only get close.
MW4371G/XAA MW5351G/XAA
Not really.
This is a common Samsung microwave diode...
- High voltage diode
#937127 - 04/16/18 12:43 AM Re: Microwave is suddenly extra noisy and not cooking [Re: johninpa]
johninpa Offline
Thanks,Jeff!
That's all there is in the model no. box.
I'll try your suggestion for a part.
John
#937132 - 04/16/18 08:16 AM Re: Microwave is suddenly extra noisy and not cooking [Re: johninpa]
johninpa Offline
No longer on site but there may be final letter G as in Model 4351G.
#937190 - 04/16/18 10:39 PM Re: Microwave is suddenly extra noisy and not cooking [Re: johninpa]
That one seems to work...
MW4351G - Common repair parts linked here.
Comes up as the same diode I linked to.
#938069 - 05/01/18 11:53 PM Re: Microwave is suddenly extra noisy and not cooking [Re: johninpa]
johninpa Offline
Diode does the trick; it's a microwave again!
Thank you ,Jeff, yet again for excellent support on my appliance problems.
John
#938089 - 05/02/18 11:21 AM Re: Microwave is suddenly extra noisy and not cooking [Re: johninpa]
johninpa Offline
Woops, egg on face. Late at night I didn't test for actual heating. I knew the old diode wasn't a diode and assumed one problem at a time!
So, no heat, new diode tests ok with 9V battery, three door switches all change continuity between open and closed door positions. I believe I have done all I should as an amateur.
I guess 20 years of nearly daily use isn't bad!
#938149 - 05/02/18 10:33 PM Re: Microwave is suddenly extra noisy and not cooking [Re: johninpa]
We sometimes run into a magnetron that damages a diode or a diode that damages the magnetron and must do both at the same time.
A quick test of the mag...
http://www.applianceaid.com/ge-otr-microwave.php
#938173 - 05/03/18 12:45 PM Re: Microwave is suddenly extra noisy and not cooking [Re: johninpa]
johninpa Offline
Thanks, Jeff!
Check 120V supplied to primary of transformer with light bulb: lights up! Re-connected.
Disconnected magnetron, run 2-4 sec: capacitor grounded: small spark, no sound (repeated three times).
New diode still has polarity.
Magnetron?
john
#938194 - 05/03/18 10:09 PM Re: Microwave is suddenly extra noisy and not cooking [Re: johninpa]
Power in, getting a spark, should tell us we are creating high voltage but the mag is not using it. Which indicates a bad mag.
