6 registered (twoshoes, bilvihur, 4 invisible), 147 Guests and 2 Spiders online.
Page 11 of 11 < 1 2 9 10 11
#935631 - 03/21/18 12:48 PM Re: Southern Mountain Rifle re-start. [Re: JasonB]
Uncle_Alvah Offline
" Serial Griller "
Loc: Vanceboro, NC
Have hit a glitch. I was removing a bit of wood to allow clearance in the lock inlet for the forward part of the mainspring, the portion right at the bend. In the process of doing so, I have exposed a small part of the ramhole. I took the pic with a steel rod in the ramrod hole to show up the break through better. This opening is about 1-1/2" up from the end of the RR hole. Figured best stop and sort it out. Not sure what to make of it, nor how to proceed exactly. I have posted this on the American Longrifle "Gun Building" forum, and would also appreciate any opinions or insights ya'll may have.
[img]https://i.imgur.com/5w8DLxY.jpg?1[/img]
I have no idea why the pic does not show
Edited by Uncle_Alvah (03/21/18 12:51 PM)
#935634 - 03/21/18 01:30 PM Re: Southern Mountain Rifle re-start. [Re: Uncle_Alvah]
Well, it's hidden, so that's something...
I assume your cut went too deep? Or had you intended to go that deep (but hit the ramrod hole unexpectedly)?
Does the spring have adequate clearance now?
#935643 - 03/21/18 04:03 PM Re: Southern Mountain Rifle re-start. [Re: JasonB]
Uncle_Alvah Offline
" Serial Griller "
Loc: Vanceboro, NC
I was working my way down bit by bit, using inletting black and it showed the front of the mainspring, where it bends, was touching wood. I was removing that black when the hole appeared.
Not sure yet. I will put inletting black on the spring,install the lock, and see if the black transfers to the rod.
Theres a whole lot of stuff going on in the relatively small area around the wrist.
#935649 - 03/21/18 05:23 PM Re: Southern Mountain Rifle re-start. [Re: JasonB]
Isn't that the wrong place for the ramrod?? Does it go down that far?? How does the lock fit, or does it?? If it is too low, bed it in epoxy to level. That should take care of hole and the lock fit. I am assuming you understand epoxy bedding??
#935654 - 03/21/18 06:07 PM Re: Southern Mountain Rifle re-start. [Re: Just_Bill]
Uncle_Alvah Offline
" Serial Griller "
Loc: Vanceboro, NC
Thats the right place. The ramrod itself is almost the exact same length as the barrel itself, breech plug face to muzzle. That way, when shooting, the powder charge, projectile, take up enough bore space to allow for adequate rod protrusion(spare me the puns, huh?) for your hands when loading.
#935666 - 03/22/18 05:34 AM Re: Southern Mountain Rifle re-start. [Re: Uncle_Alvah]
Got it.
#935672 - 03/22/18 08:09 AM Re: Southern Mountain Rifle re-start. [Re: Uncle_Alvah]
Uncle_Alvah Offline
" Serial Griller "
Loc: Vanceboro, NC
Turns out its not an especially big deal. If the spring/rod clear, no sweat. If they are in significant contact, I can either remove a hair of thickness off the spring and/or take a bit of thickness off the rod.
Trouble? Simple. Don't start none, won't be none.
#935676 - 03/22/18 09:16 AM Re: Southern Mountain Rifle re-start. [Re: Uncle_Alvah]
That makes sense to me. It's a cosmetic fault in a cosmetically irrelevant location.
