Page 10 of 11 < 1 2 8 9 10 11 >
#934353 - 03/05/18 05:59 PM Re: Southern Mountain Rifle re-start. [Re: JasonB]
Uncle_Alvah Offline
" Serial Griller "
Loc: Vanceboro, NC
They make a CO2 ball remover but I'm too cheap to buy one.....
#934380 - 03/06/18 08:01 AM Re: Southern Mountain Rifle re-start. [Re: Uncle_Alvah]
We had an open frame roof structure overhead. Used a T-handled rod with the worm, got the worm threaded into the ball, hooked the T-handle on a beam, and tap-tap'd the rod out. Took quite a bit of force (patched ball, rifled barrel). Really didn't want to mar the beautiful stock!
#934422 - 03/06/18 06:56 PM Re: Southern Mountain Rifle re-start. [Re: JasonB]
The breech does usually come off, but not easily. Last resort...
#934705 - 03/12/18 11:51 AM Re: Southern Mountain Rifle re-start. [Re: Just_Bill]
Uncle_Alvah Offline
" Serial Griller "
Loc: Vanceboro, NC
but not easily
Thats a fact! Helps if the builder or factory used a little anti-seize.
Trouble? Simple. Don't start none, won't be none.
#934710 - 03/12/18 12:23 PM Re: Southern Mountain Rifle re-start. [Re: Uncle_Alvah]
Anti-seize - No workshop should be without. All metal-to-metal threads get it at my shop.
#934711 - 03/12/18 12:54 PM Re: Southern Mountain Rifle re-start. [Re: JasonB]
Uncle_Alvah Offline
" Serial Griller "
Loc: Vanceboro, NC
On some of the machines I worked on at IBM there were steel screws threaded in aluminum. My co-workers, one of whom may be the next one to have to take it apart, would beat someone with a stick for not using it.
I'd be surprised to hear of a barrel factory using it.
I'd be shocked to hear of a builder who doesn't.
#934712 - 03/12/18 01:03 PM Re: Southern Mountain Rifle re-start. [Re: Uncle_Alvah]
A few years back, I designed a mounting arm for a sonar transducer for our environmental sciences group. Built all from aluminum, and using stainless bolts with nylock nuts....
Just the act of hand-screwing the nylock nuts onto the stainless bolts caused one to sieze so hard that I sheared the bolt trying to unthread it. I introduced the environmental sciences group to anti-seize as a result.
Yup, a desk dweller's pale fingers were enough to seize the nylock onto the bolt! 3/8" bolt, IIRC.
#935291 - 03/18/18 09:51 AM Re: Southern Mountain Rifle re-start. [Re: JasonB]
Loc: Huntsville AL
WOW! If that was a from someone I didn't know I would not believe it. I would not doubt your credibility, that is really something.
#935343 - 03/18/18 07:04 PM Re: Southern Mountain Rifle re-start. [Re: Able_Dog]
Anything stainless with anything else, needs anti-seize!!!!
#935377 - 03/19/18 07:40 AM Re: Southern Mountain Rifle re-start. [Re: Just_Bill]
Yessir!
