4 registered (Gary O', 3 invisible), 236 Guests and 3 Spiders online.
Page 4 of 11 < 1 2 3 4 5 6 10 11 >
#919383 - 07/20/17 02:29 PM Re: Southern Mountain Rifle re-start. [Re: Just_Bill]
Uncle_Alvah Offline
" Serial Griller "
Loc: Vanceboro, NC
This is what I came up with to repair the excessive gap at the front of the tang. Small piece of wood glued to the side of the cut. There will be another one on the other side as well. The problem of how to clamp such a small piece I solved, hopefully, by placing a wedge(screwdriver) in between the repair piece and a backer on the other side of the cut.
Trouble? Simple. Don't start none, won't be none.
#919400 - 07/20/17 06:45 PM Re: Southern Mountain Rifle re-start. [Re: Uncle_Alvah]
I am sure it was covered somewhere before, what is the wood of the stock???
#919411 - 07/20/17 08:33 PM Re: Southern Mountain Rifle re-start. [Re: Just_Bill]
Uncle_Alvah Offline
" Serial Griller "
Loc: Vanceboro, NC
Curly Ash
#919448 - 07/21/17 11:18 AM Re: Southern Mountain Rifle re-start. [Re: Uncle_Alvah]
FredDwyer Offline
Loc: Connecticut, USA
So what you are doing here, is playing a game of "You Bet Your Ash."
Fred
#919471 - 07/21/17 03:49 PM Re: Southern Mountain Rifle re-start. [Re: Uncle_Alvah]
Nice stuff, ash, I built a car out it. Hard, but workable. You already have a bundle in the stock, measure MANY times, cut once!!!! I would wonder that magic marker would soak in to some degree requiring excessive sanding. Lamp black should not do that. Scribe with a utility knife, then rub lamp black into the cut, finish short of the line.
#919891 - 07/28/17 10:29 AM Re: Southern Mountain Rifle re-start. [Re: Just_Bill]
Uncle_Alvah Offline
" Serial Griller "
Loc: Vanceboro, NC
I pretty much stopped work to regroup and repair, as best I am able, the glaring mistakes made inletting the tang. I made and glued an insert to fill the cut and I also cleaned up the red and blue careless marking. I then masked off the area to keep it from happening again with the inletting black. The cut at the rear of the tang is about 1/8" too long. This I figure to cure by have the end of the tang welded then I'll shape it to be about 1/8" longer.
I have also ordered a couple new chisels, Narex.
This is a lot more difficult than I figured, but I'm fine with that. I don't want to "move on" until I get these glitches "fixed".
#920652 - 08/07/17 10:54 PM Re: Southern Mountain Rifle re-start. [Re: Uncle_Alvah]
Uncle_Alvah Offline
" Serial Griller "
Loc: Vanceboro, NC
This patch may not be the best it could be, but its the best I could do....
#920666 - 08/08/17 09:09 AM Re: Southern Mountain Rifle re-start. [Re: Uncle_Alvah]
Not bad at all, methinks. Pretty clean match at the end-grain.
#920670 - 08/08/17 10:45 AM Re: Southern Mountain Rifle re-start. [Re: JasonB]
Uncle_Alvah Offline
" Serial Griller "
Loc: Vanceboro, NC
Most of it will be removed for the tang, but I still wanted it as best I could get it.
#920672 - 08/08/17 10:52 AM Re: Southern Mountain Rifle re-start. [Re: Uncle_Alvah]
Uncle_Alvah Offline
" Serial Griller "
Loc: Vanceboro, NC
I bought a lighted magnifier lamp. Not as adjustable as I expected but its still a big big help!
