3 registered (Suenmark98, 2 invisible), 268 Guests and 3 Spiders online.
#920160 - 08/01/17 03:23 PM Are woodburning attachments to furnaces clean?
Hammer Offline
Loc: Northern U.S. where the Winter...
My dad and I are looking at buying a house together. We found a house that has a gas furnace (uses LP gas) with a woodburning attachment. The realtor said the owners used it quite a bit and loved it. I would love the idea of having something like that since the house is in a wooded area. Free heat! What's not to love?
Well, my dad is of a different opinion. He thinks electric heat is the best since it's quiet. He also believes using the woodburning attachment would put smoke in the house. Is that true? Even a little? I can't imagine it would do that. Who would want that???
#920177 - 08/01/17 07:27 PM Re: Are woodburning attachments to furnaces clean? [Re: Hammer]
bilvihur Offline
Loc: Hudson Valley, New York
No matter how carefully you feed a wood stove, there's always a little smoke that escapes. That translates into smell and dust. Then there's the debris that comes in with the logs. And you'd better keep the chimney clean!
Others will post in with the relative costs of different heating methods, but I can't imagine electric is much quieter than gas.
#920239 - 08/02/17 02:42 PM Re: Are woodburning attachments to furnaces clean? [Re: bilvihur]
Hammer Offline
The electric I was referring to would be baseboard electric heaters. All they do is silently generate heat, except for some popping sounds as the metal expands from heating up.
As for the "dirtiness" of the woodburning stove attachment, would it be from smoke being distributed through the ducts? That's my only real concern. I understand having dust brought in with the logs and so forth. That much is to be expected.
#920588 - 08/06/17 04:15 PM Re: Are woodburning attachments to furnaces clean? [Re: Hammer]
BigJohnfromNY Offline
Loc: Southwestern CT USA
So while I can't specifically comment on woodburners I can tell you that a number of years ago I retrofitted my oil fired forced hot air system with a supplemental coal furnace attached to the same duct work and using the fan on the oil unit as the mover of heat. Ran primarily on coal. If fire got cool or went out the oil burner would kick in. Point is, I never had a coal gas smell in the house. The house was never warmer. I think draft might be the key. Good luck.
My dog is unaffected by the Helmholtz Resonance.
#920632 - 08/07/17 03:44 PM Re: Are woodburning attachments to furnaces clean? [Re: BigJohnfromNY]
Hammer Offline
Thank you! It sounds like this woodburning attachment might be a real winner then. I'll definately be giving it a try if we end up buying the house.
