#919076 - 07/17/17 09:04 AM Pool Heater breaker - 40 amps
wsommariva Offline
Loc: Northern NJ
Hi everyone,
My 7 or 8 year old pool heater breaker is outside in a panel. Summer use only. We turn the breaker on and off to control the heater. Maybe 15 times a year.
220 volts, I think it's 40 amps.
Today the heater would not turn on. After I flipped the breaker a dozen times it kicked in.
Easy enough to replace the breaker, anything else I should check first?
BTW a few years ago the breaker would flip closed all by itself. The panel is next to the vibrating heater - HEAT PUMP. You guiuys told me to check the connections to the breaker and sure enough they were quite loose. I will check that first.
Question is, how long do breakers last if you flip them on and off 15 times a year?
Thanks
I certainly ask enough questions...
I was never good at spelling....
#919078 - 07/17/17 09:17 AM Re: Pool Heater breaker - 40 amps [Re: wsommariva]
Originally Posted By wsommariva
...how long do breakers last if you flip them on and off 15 times a year?
Seven or 8 years...
(Kidding. Sorry, I just couldn't resist...)
Maybe an electrician will chime in, but seriously, it's a mechanical switch, subject to heat/cold/moisture/etc. It's unreasonable to think it will last forever, which I don't sense is your expectation. Too many external variables, coupled with the manufacturer's planned B10 life to say "X-years" is my guess. smile
#919079 - 07/17/17 09:24 AM Re: Pool Heater breaker - 40 amps [Re: wsommariva]
Loc: muttonville,ny
Depends on load at the time of switching.
If under heavy load it may only last a year or so.
It may help to turn down thermostat before turning off breaker.
8 years may be normal for that application.
" Life is like a piano....
#919080 - 07/17/17 09:25 AM Re: Pool Heater breaker - 40 amps [Re: wsommariva]
wsommariva Offline
Loc: Northern NJ
Thanks guys. I though it would outlast me.
I'll put in a new one.
#919087 - 07/17/17 10:23 AM Re: Pool Heater breaker - 40 amps [Re: wsommariva]
Life depends on whether or not the breaker is "switch rated"
It's hard to see, in the small print, but there usually is
a small 'swd' in the description on the breaker, IF it is switch rated.
So, yes, it can be used as a switch, but for how long is speculative.
I know one application where the breakers are used as switches
every day, primarily for lights. most are 25-30 years old.
#919100 - 07/17/17 12:36 PM Re: Pool Heater breaker - 40 amps [Re: BillJeffy]
wsommariva Offline
Loc: Northern NJ
I'll get what Lowe's has as long as it fits. If they have a switched one I'll get that.
Thanks for the info
#919104 - 07/17/17 12:48 PM Re: Pool Heater breaker - 40 amps [Re: wsommariva]
wsommariva Offline
Loc: Northern NJ
Can't find a swd on line anywhere. Any idea who sells them?
#919105 - 07/17/17 12:53 PM Re: Pool Heater breaker - 40 amps [Re: wsommariva]
Loc: muttonville,ny
https://www.platt.com/platt-electric-sup....aspx?zpid=6585
Breaker, Miniature, Switch Duty Rated
Edited by code_ceis (07/17/17 12:54 PM)
#919109 - 07/17/17 01:28 PM Re: Pool Heater breaker - 40 amps [Re: code_ceis]
wsommariva Offline
Loc: Northern NJ
All riggghhht.....thanks very much.
I still need to see if Eaton is compatible with the service panel right?
#919200 - 07/18/17 11:36 AM Re: Pool Heater breaker - 40 amps [Re: wsommariva]
wsommariva Offline
Loc: Northern NJ
More info. The panel is a Seimans, the bad breaker is a Square D.
Just found that the panel lists all breakers that can be used.
Under "Double" it lists Cutler Hammer BR. Square D HOM. I will look for that.
Edited by wsommariva (07/18/17 11:54 AM)
