4 registered (Gary O', 3 invisible), 236 Guests and 3 Spiders online.
#913760 - 05/15/17 03:32 PM Removing Bonnet on Delta Faucet
nicki1 Offline
Loc: Maryland
I need to replace the cartridge on my Delta shower faucet. An easy fix is turning to be difficult. When I try to remove the bonnet holding the cartridge in, it won't budge. Turning it counterclockwise without success. Sprayed penetrating oil this morning and hope that works. I have hard water and that is not helping matters. Any suggestions are welcomed and appreciated. Thank you very much!
#913767 - 05/15/17 04:52 PM Re: Removing Bonnet on Delta Faucet [Re: nicki1]
Try some Lime-Away, or vinegar. That should help dissolve the hard water build up.
#913773 - 05/15/17 05:57 PM Re: Removing Bonnet on Delta Faucet [Re: nicki1]
I assume you have tried a strap wrench?? If it was never removed and is old, you may have to resort to a pipe wrench, then get a new one. I usually use plumbers grease on all threads when I take faucets apart, makes it much easier the next time.
#913781 - 05/15/17 07:01 PM Re: Removing Bonnet on Delta Faucet [Re: nicki1]
nicki1 Offline
Loc: Maryland
Thanks for the advice and views. The bonnet is off (used a large crescent wrench) as the penetrating oil worked its magic. I bought lime away Otw home and did not need to use it. Thanks again.
