#79605 - 05/31/04 03:52 PM
No cold air!
As I mentioned in a previous post, we just replaced our furnance and evap coil in the garage and left our old condeser outside.
Well, today was a hot one and the a/c has been running a lot.
I noticed about an hour ago that we were not getting cold air.
The fan is just recirculating the air in the house. I checked the outside unit and I can see that the fan motor is running but the air doesn't feel hot coming out.
Does it sound like we have a freon leak?
Anything else I can check before calling a pro?
Thanks,
Drew
#79607 - 05/31/04 06:17 PM
It's working again!
I turned the whole system off for a couple of hours and turned it back on about an hour ago because we were starting to melt and it started working again. We are now back down to 75 degrees.  I wonder if the evap coils could have gotten froze up? I'm not sure if I mentioned this before but we have a two story house (1400 sq ft) and only this one a/c system to do the job. Needless to say, the upstairs is always warmer than the downstairs. In an effort to equalize the air flow, I closed off two vents downstairs and it did seem to make a difference. However, I wonder if this is bad for the system? Could this cause the coils to freeze up? Any other idea why it would just start working again? Thanks, Drew
#79608 - 06/01/04 08:10 AM
Re: It's working again!
Loc: Rochester, MN
Drew,
Lack of air flow can cause the coil to freeze up. So I take it the furnace/air handler w/ the A/C is just cooling the upstairs area along with a couple of vents for down stairs?
For the A/C unit how many vents does it have? If it have say 5 vents, and you close off 2, for sure you will have some problem.. Also how many BTU/Ton is it?
-Jay
#79609 - 06/01/04 08:27 AM
I think it's a 3 ton unit for a 1400 sq foot house. This one unit serves the whole house.
There are 4 vents upstairs and 4 vents downstairs.
The vents downstairs have the most airflow, however.
It would be nice if there was a way to divert more air upstairs without closing off the downstairs vents.
Also, we have this return air duct in the upstairs hallway which doesn't do a thing as far as I can tell. If you put a piece of tissue up to it while the a/c is running it won't even stay in place.
Drew
#79611 - 06/01/04 09:19 AM
Loc: West Virginia
(However; it seems an unfathomable secret to the majority of posts on DIY sites that an air cooling or heating system is directly related to air flow.) Lmao now for the good part (That is why AC techs have thermometers and air pressure and flow reading devices) HOLLLLD It Harold First you say it has nothing to do with air flow , Which even i knew ya was full of crap with that.. Then techs have Flow rate Testers, what for u say it dont have anything to do with air flow . I belive its time for you to be dismissed permently , U contradict your self more times in one day than any man i have ever known
Edited by Briggs_Man (06/01/04 09:21 AM)
C&K Lawn Care You Grow it, We'll Mow it
#79612 - 06/01/04 09:19 AM
Loc: Rochester, MN
Drew,
If it just 8 vents, sure don't have enough (depends on size) vents. As for the return, if it not holding a tissue paper, is there any type of air flow going in it? If you feel nothing, I'd go up take a look! Duct may of came undone, and you are pulling hot air out of the attic.
-Jay
#79614 - 06/01/04 10:03 AM
So what is my best course of action with respect to the vents?
Keep them all fully open or can I close some of them partially?
Are there any vents that are crucial to keep fully open, such as the one closest to the blower?
Drew
#79616 - 06/01/04 10:22 AM
I have yet to have a company suggest this. Nothing against the guys that installed my unit, but I doubt they are competent at doing these types of calculations.
The other "service man" that we had out was more intersted in selling us a new $5,000 a/c system than doing anything that required actual work.
Drew
#79618 - 06/01/04 06:40 PM
It stopped working again.
Our a/c system stopped putting out cold air again today. I was able to get the guys that installed our coil back out and they determined that evap coils were NOT freezing, but the compressor was not coming on all the time. Apparently, when the old compressor gets overheated it just shuts down.  So, to get us through for another day or two they installed a "hard start" or "kick start" on the outside unit. Looks like this big capacitor. Anyone familiar with this technique? They said it might not last long... Drew
Edited by drewlane (06/01/04 06:41 PM)
#79620 - 06/01/04 08:00 PM
Re: It stopped working again.
Cool...maybe we will make it through the summer after all. Is this a typical situation with an old compressor requiring the hard start kit? What exactly is wrong with the compressor that it won't come on without the extra "kick"? BTW, do you think I'm ready to start my own a/c repair service now?  Drew
#79622 - 06/01/04 08:56 PM
Damn, and I thought the hard start kit was the cure all of the a/c biz.  I doubt I'll take any courses, but this a/c stuff is pretty fascination what with the physics and all. I think I'll stick to writing software, although I would probably make more with the Texas a/c service.  Drew
#79624 - 06/02/04 08:28 AM
superheat adjustment needing fine tuning and non-condensibles needing removal
Just curious - how is this typically done?
Drew
#79625 - 06/02/04 08:36 AM
Forgot to mention this, but I had the service tech take a look at my upstairs return vent that wasn't doing anything and turns out it had been drywalled in!
He cut a hole in the drywall downstairs where it was supposed to meet with the downstairs return and viola it's sucking some air. It's not pulling in as much as the downstairs return, but at least it's doing something now.
I suspect it's been this way since the house was built 20 years ago!
Drew
