8 registered (BobR, kickintile, Able_Dog, bilvihur, jigs, 3 invisible), 35 Guests and 3 Spiders online.
#723834 - 08/06/12 12:03 PM holes in doors from using door stops
http://www.allaboutdoors.com/popup_image.php?pID=361706
have a few of these in the house ---- they put holes in the hollow doors. I have taken them off but looking for something round that i can use to cover up the holes approx 1 inch around.
#723835 - 08/06/12 12:07 PM Re: holes in doors from using door stops [Re: Anonymous]
I've taken a 2"x2" piece of luan, put a slight bevel on the edge, stained/painted to match, and glued/pinned it in place.
#723837 - 08/06/12 12:24 PM Re: holes in doors from using door stops [Re: CabinConnection]
sorry what is luan?
#723840 - 08/06/12 12:42 PM Re: holes in doors from using door stops [Re: Anonymous]
kickintile Online   content
Loc: Northern Colorado
if the doors are painted, I use a piece of mesh drywall tape and drywall mud..
two light coats will get it..
prime and paint..
kick
Life is all about [censored], you're either covering it, hauling it, laughing it off, kicking it, kissing it, busting it, trying to get a piece of it, or behaving like one.
#723843 - 08/06/12 12:57 PM Re: holes in doors from using door stops [Re: kickintile]
door have a patteren on them so it needs to be something round so it looks good
#723850 - 08/06/12 01:40 PM Re: holes in doors from using door stops [Re: Anonymous]
Loc: Eagle, CO USA
After you patch the holes, move the door stops so they won't repeat the process. If the door opens against a wall, put the stop on the door near the edge where there is wood behind the panel and where it will hit the wall base molding. With the stop on the door, it will also be easier to vacuum around it.
