5 registered (dave, CabinConnection, 3 invisible), 31 Guests and 1 Spider online.
#723121 - 07/27/12 09:39 PM Maytag Washer wont stop filling with water?
BoiseHM Offline
I have a 2004 Matag Atlantis Washer (Model # MAV7551AWW) that keeps filling with water after it begins to agitate. Im thinking the water valve is bad... what does everyone elce think?
thanks Chris
#723135 - 07/28/12 04:00 AM Re: Maytag Washer wont stop filling with water? [Re: BoiseHM]
Clint_Robbins Offline
Does it overfill or does it stop sometime after agitation starts?
I'm not a pro, but overfilling could be caused by a bad water level sensor not sending a signal to the valve or by a bad valve. I used to have problems with sediment particles getting into the solenoid valve but corrected that by installing a whole house sediment filter.
#723145 - 07/28/12 06:32 AM Re: Maytag Washer wont stop filling with water? [Re: BoiseHM]
How do you get the water to stop? That can help split up the possible trouble makers...
http://www.applianceaid.com/washing-machine-overfilling.php
That model has used 2 different valve...
Water inlet valve Manufacturer Number 22003384
Water inlet valve Manufacturer Number 22004333
And 2 different pressure switchs (water level controls )...
Pressure Switch Manufacturer Number 22004069
Pressure switch Manufacturer Number 22003963
#723148 - 07/28/12 07:01 AM Re: Maytag Washer wont stop filling with water? [Re: jeff1]
BoiseHM Offline
Jeff i can turn the water temp to cold only and push the timer knob in and it stops filling. When i turn it to hot and push the timer knob in it doesn't stop filling. When i put the water leavel to small on cold it works fine it fills then starts to adgitate and work properly. When i put the water selector to warm or hot it fills to where the small load water level should be and begines to adgitate and keeps filling with water... btw on hot or cold it keeps filling after i push the timer knob in to shut the machine off.
Thanks for the help
Chris
Edited by BoiseHM (07/28/12 07:05 AM)
Edit Reason: spelling
#723149 - 07/28/12 07:02 AM Re: Maytag Washer wont stop filling with water? [Re: BoiseHM]
BoiseHM Offline
Btw whats the difference in the 2 water valves and pressure switches?
#723178 - 07/28/12 01:54 PM Re: Maytag Washer wont stop filling with water? [Re: BoiseHM]
Hot 1/2 of the fill valve has failed and is sticking open = new fill valve time.
Series of the washer ( first 2 digits of the serial # )...may have to call and ask which is for yours.
#723249 - 07/29/12 01:15 PM Re: Maytag Washer wont stop filling with water? [Re: jeff1]
BoiseHM Offline
Thank you for the help once again Jeff!!!
Chris
#723269 - 07/29/12 06:34 PM Re: Maytag Washer wont stop filling with water? [Re: BoiseHM]
bilvihur Offline
Loc: Hudson Valley, New York
You can always try dissembling and cleaning it first. Applying 110V and hearing a click would be a simple bench check. Might save some $$.
#723271 - 07/29/12 09:54 PM Re: Maytag Washer wont stop filling with water? [Re: bilvihur]
Not -normally- a good idea, a copy: we do not recommend taking these valves apart and cleaning them as they usually will leak if you do this and you also take the risk of the valve sticking in the open position and flooding your house. The diaphragms in these valve swell over time and become deteriorated.
#723403 - 07/31/12 04:17 PM Re: Maytag Washer wont stop filling with water? [Re: jeff1]
BoiseHM Offline
I ordered a new one, it will be here today on the brown truck!!!
