6 registered (CabinConnection, Bob_Q, twoshoes, yardmaster, 2 invisible), 47 Guests and 2 Spiders online.
#720315 - 07/01/12 10:21 AM Re: Got Backhoe? [Re: BillJeffy]
The pic implies an articulated backhoe?
Is this a valid assumption?
#720360 - 07/01/12 07:48 PM Re: Got Backhoe? [Re: notnew2diy]
NO, it was just a pic I pulled off the net,
implying a BIG tractor/backhoe, Vs the skimpy lawn tractor
with attachments.
THIS is one I was looking at......
I was trying to keep the photo small so you-know-who
woulnd't scorch me for having to scroll
#720370 - 07/02/12 02:07 AM Re: Got Backhoe? [Re: BillJeffy]
Well, if you'd pull in that back arm, your damn photo wouldn't have to be so frigg'n WIDE!
wink
#720373 - 07/02/12 04:14 AM Re: Got Backhoe? [Re: BillJeffy]
1 - An assumption is made that you will perform your own work/maintenance. Local parts availability should be your main concern. On the off-hand that you are unable to fix something, dealer support.
2 - Get the correct size. ie..you gonna fill dump trucks? Will the bucket easily reach?
3 - One friend said this:
The parts for the JD are easier to find used. The Ford should be cheaper it they are in the same shape. Ford have a pretty good hoe but the resale is not as high as JD or Case.
If I was buying a used hoe it would be a Case or JD. The parts is the reason. Ford can be a real pain to get some parts for their construction equipment. There is not a real Ford construction dealer within a days drive of me.
4 - Another friend:
New tires and hydraulic hoses don't come cheap.
Wife's uncle retired as a heavy equipment mechanic about 2 years ago. His advice is Deer as they are the easiest to get parts for both new and used.
5 - One last friend's comments:
As a professional, definitely the Deere- the Ford is a good, and strong, hoe, but if you have to work on it.. Anything but a Case. Case sold a lot of hoes because they were cheap and they offered great financing- but they don't hold up well.
HTH..good luck...notnew...
#720413 - 07/02/12 09:12 AM Re: Got Backhoe? [Re: BillJeffy]
Own work, maintenance - Yup
A friend does heavy equip service,
but if it got real expensive, I'd probably dump it.
Hence, not looking for high dollar unit.
Size = moving gravel/grading, and pulling stumps
general stuff around the property....
and there's always SNOW, if we get any !!
Looks like JD is the general consensus,
and i'll admit a long time company with a good name,
and I anticipate (hopefully) being able to resell it
when I get finished (years)
