2 registered (2 invisible), 67 Guests and 1 Spider online.
#720367 - 07/01/12 10:07 PM TV Antenna Question
Is it beneficial to use a signal splitter in reverse to combine signals from 2 antennas to make a stronger single feed?
#720440 - 07/02/12 01:11 PM Re: TV Antenna Question [Re: RCovell]
Loc: Eagle, CO USA
No replies? Maybe you should post in the computer forum.
As a guess, I'd say the only benefit to using two antennas is to grab signals from two directions. Not sure if you need a splitter for that. Remember that a splitter includes signal losses; the cheaper ones are probably more lossy.
For just increasing signal strength from one direction it is best to buy a larger antenna that has a higher gain. That type of antenna would also be more directional, to some degree.
#720441 - 07/02/12 01:17 PM Re: TV Antenna Question [Re: RCovell]
JMac Offline
Loc: Cary, North Carolina
Here is a good article on the subject, though I wish he would have proof-read it and eliminated the typos.
HDTV Antenna Reception
"Pain is temporary, quitting lasts for ever." Lance Armstrong
#720442 - 07/02/12 01:18 PM Re: TV Antenna Question [Re: Bob_Fleming]
Cursory Google on this topic, if I understand what I read, was that two antennas will result in "ghosting"... Too complicated for my simple mind however, but there is LOTS of information on the 'net...
#720444 - 07/02/12 01:27 PM Re: TV Antenna Question [Re: RCovell]
JMac Offline
The article I posted recommends an antenna for each TV and if the stations are more than 70 degree a rotator for the antenna to point it at the right station. If you want a single antenna and multiple TV's you should put in an amplifier.
#720445 - 07/02/12 01:29 PM Re: TV Antenna Question [Re: RCovell]
Loc: N Georgia
Maybe as mentioned antennas to grab specific stations from two different directions and an "A-B" switch rather than a reversed splitter, but I have no idea.
But it seems a good antenna and a rotator would be better than above.
#720472 - 07/02/12 07:13 PM Re: TV Antenna Question [Re: RCovell]
Never heard of combining two antenna for a stronger signal. Don't think it would work. You could combine two or more antennas from different directions though instead of using a rotor however.
