0 registered (), 18 Guests and 1 Spider online.
#718271 - 06/08/12 06:41 PM Propane Hot Water Heater
JerryWayne Offline
I plumbed in a used water heater. I have almost no water pressure on the hot water faucet. I have good pressure on the cold . All valves are open and my prssure on my holding tank reaches 50 lbs. Both the hot water tank and my holding tank are full of water. I have bled off the air, but have very, very little hot water pressure..Please help me!!!
#718273 - 06/08/12 07:09 PM Re: Propane Hot Water Heater [Re: JerryWayne]
bilvihur Offline
Loc: Hudson Valley, New York
It's a PITA, but do you have good flow from the shutoff valve if you remove the supply tube? If yes, it could be the faucet cartridge/washer itself.
#718281 - 06/09/12 05:20 AM Re: Propane Hot Water Heater [Re: bilvihur]
JerryWayne Offline
My next move I guess is to cut the hot water line and put a shutoff there and see if I have water pressure at the valve. Have you ever heard of a tube in the tank being pluggeg? If so how would I clear a plugged line in the tank??
#718343 - 06/10/12 06:42 AM Re: Propane Hot Water Heater [Re: JerryWayne]
Loc: N Georgia
Did you check more than one hot water faucet?
#718370 - 06/10/12 02:26 PM Re: Propane Hot Water Heater [Re: Able_Dog]
JerryWayne Offline
I did check them all...they are not plugged...I'm wondering if I have a bladder problem in the holding tank?..Do you know how much air pressure I should have in a 20lb. tank??
