I am in the process of remodeling a room for my recently moved back in daughter.To speed up the job I used prefinished panelboard.Because the house is older and "settled" the resulting gaps at corners,due to the room not being square, preclude the use of the plastic trim/moulding commonly used with panelboard, the gaps are too wide.I am using the foam/polystyrene type simulated wood trim. because of the gaps I have to run a vertical peice of trim from baseboard to ceiling to hide the vertical corner joint.How do you join these three angles at the ceiling corner.I am using(not sure what it's called)trim w/a 90 deg hidden corner and a 1/4 round concave face.I can't seem to figure out how to do this.How to cut the trim so all three mouldings fit together at ceiling corner joint??? Thanks for any help!!!
