4 registered (CabinConnection, kickintile, Able_Dog, Bob_Q), 36 Guests and 1 Spider online.
Page 3 of 4 < 1 2 3 4 >
#708580 - 03/10/12 06:31 AM Re: seized spark plug [Re: CabinConnection]
Able_Dog Online   content
Loc: N Georgia
#708593 - 03/10/12 07:58 AM Re: seized spark plug [Re: CabinConnection]
kframe19 Offline
Loc: Virginia
Actually, the cold is FAR more controllable. You don't have to worry about overheating one particular area of the head and possibly warping it.
By freezing the entire device, the spark plug and head contract away from each other, not only breaking the adhesions but also allowing room for subsequent applications of penetrating oil to get into the threads.
THAT'S RACIST!
#708599 - 03/10/12 08:20 AM Re: seized spark plug [Re: notnew2diy]
Originally Posted By: notnew2diy
If all else fails, clean area w/brake cleaner and bring out the heat.
YMMV...notnew...
warning warning
Make sure the brake cleaner is completely gone before you heat or you could die. Brake cleaner + heat = phosgene gas.
http://www.brewracingframes.com/id75.htm
Edited by jdevlin (03/10/12 08:22 AM)
#708600 - 03/10/12 08:31 AM Re: seized spark plug [Re: kframe19]
You're probably correct. My personal reference point is D-11s and such... crazy
#708630 - 03/10/12 03:26 PM Re: seized spark plug [Re: jdevlin]
Thank you very much.
I did not know.
...notnew...
#708632 - 03/10/12 04:15 PM Re: seized spark plug [Re: jdevlin]
Loc: N Georgia
Wow, that's a scary article!
#708678 - 03/11/12 10:20 AM Re: seized spark plug [Re: BillsFan]
BillsFan Offline
Loc: Pa
finally got it out...was just about to throw it in the garbage when I reached for the big hammer and wacked it real hard..I couldn't believe it started to turn...it came out with just my fingers after that...threw in a new plug and it started right up....a little smoke but I think that is just from the fuel that leaked out on the motor.
I want to thank you all for your help.....saved me a hundred bucks.
when I'm screaming at them it's really not personal
#708688 - 03/11/12 11:39 AM Re: seized spark plug [Re: BillsFan]
Loc: N Georgia
Sometimes a big hammer is the right tool, LOL.
Now remove the new plug in the next couple of days and put some anti-seize compound on it.
Glad it worked out for you.
#708695 - 03/11/12 01:47 PM Re: seized spark plug [Re: Able_Dog]
Ya know...
One possible cause for stuck plugs is if the plugs' threads protrude into the cylinder. Carbon can build up on these last few threads, making removal "difficult".
Proper plugs usually don't have this problem, but often people will mess around with plugs that while they may fit and work, they are not the correct length.
Something to double check... On both the remnants of the removed plug, as well as on the new one when you take it out to apply just a tiny amount of never-seeze.
#708697 - 03/11/12 01:57 PM Re: seized spark plug [Re: CabinConnection]
BillsFan Offline
Loc: Pa
just took a look at it....your right...new plug went in further than the ole one.........runs like a dream...2 primes 2 pulls and it runs great...even with last years gas..yes i know gas is good only for a month they say but I'm not about to dump it out with the prices of gas now.
Originally Posted By: CabinConnection
Ya know...
