2 registered (kickintile, 1 invisible), 36 Guests and 3 Spiders online.
#707092 - 02/27/12 03:47 PM Re: ryobi cs26 weedeater [Re: Deb852]
saugen48 Offline
Loc: Halifax, Canada.
OP must have ran away....
ASUS G74SX-Win7
Tosh Sat L650 Win7SP1
Acer 7720 Vista UltSP2
Acer Aspire 5517 WinSP1
HP Mini210 Win7(S)
BB Playbook 32GB
Acer Iconia A110 w/JB
#707148 - 02/28/12 05:10 AM Re: ryobi cs26 weedeater [Re: Deb852]
Eh, they may return. Could be a weekend persuit for'em.
#707255 - 02/28/12 11:31 AM Re: ryobi cs26 weedeater [Re: Deb852]
Deb852 Offline
Im back.. So whats it gonna be.? I hear fuel carburetor problems, ignition, If so, Wheres the ignition?...Stale gas, Ive changed the gas and no luck, with so many could've been, And yall just guessing.. Please give me the correct answer and stop guessing... This weekend requires some long [censored] fixing with so many guesses..
#707268 - 02/28/12 12:38 PM Re: ryobi cs26 weedeater [Re: Deb852]
Deb,
You have to provide us information in order for us to come to a correct solution. The most important question to be answered is above. I'll repeat it here:
"I'd like to know how this problem came to be. Is this machine just out of off-season storage, or has this developed during regular use? when did it last run correctly?"
Surely you understand that we cannot see/smell/touch your particular machine, and thus what you tell us is all we can go on. It may take a few itterations of test/result/recommendation to come to the ultimate solution.
The history of the problem is the first step. The problem you've described can be caused by a few different things.
If the machine is just out of off-season storage, it's quite likely a problem related to fuel degradation. This can result in simply needing to switch out the fuel, or if worse, can require a complete carburetor rebuild and fuel line replacement.
If it was running fine and just began quitting regularly, it could be another set of issues, perhaps ignition related, or perhaps fuel system related. The fuel pickup could have simply fallen off in the tank, or a fuel line could be pinholed.
Stick with us, we'll solve the problem. If you're in a hurry for easy answers, pay your local repair man instead. He'll do the same thing, but without the time required for the back and forth that solving this by internet forum will require.
Given the chance and a willing OP, our success rate in small engine repair is quite good, and very economical.
#707283 - 02/28/12 01:13 PM Re: ryobi cs26 weedeater [Re: Deb852]
Deb852 Offline
Okay, I will get back with yall.. Thanks for your patience!!
#707284 - 02/28/12 01:21 PM Re: ryobi cs26 weedeater [Re: Deb852]
Great!
Now....
Moderator:  Bob_Q, Ernie
