9 registered (mariamang, JimTheTinkerer, Joe_Guy, kickintile, CabinConnection, captain150, 3 invisible), 45 Guests and 2 Spiders online.
Page 2 of 4 < 1 2 3 4 >
#703610 - 01/31/12 02:08 PM Re: Jackhammer noise in wall??? NOT water hammer? [Re: CabinConnection]
FranS Offline
DIDn't a gal post a similar thing, some time back. and, it turned out to be some pump down the street?
#703617 - 01/31/12 04:02 PM Re: Jackhammer noise in wall??? NOT water hammer? [Re: FranS]
Similar, but different... This OP, as I understand the posts, maintains there's no water pipes in the offendng wall.
#703623 - 01/31/12 05:04 PM Re: Jackhammer noise in wall??? NOT water hammer? [Re: CabinConnection]
FredDwyer Offline
Loc: Connecticut, USA
I like the "woodpeckers in the attic" scenario. I think the OP should plan on going up into the attic the next time the noise is present.
Fred
#703643 - 01/31/12 07:38 PM Re: Jackhammer noise in wall??? NOT water hammer? [Re: FranS]
Similar,..... and it took 15 MONTHS to finish that thread... sick
#703655 - 01/31/12 10:12 PM Re: Jackhammer noise in wall??? NOT water hammer? [Re: emg2525]
Noises frequently today, but not quite as bad. Can't rule out anything, but I don't think a woodpecker would disappear and come bac 2 months later, would it? Not sure if plumbing in the wall...it's an exterior wall that faces the north. Suppose tomorrow I should put food coloring in all the the toilets and check for a leak.
#703662 - 01/31/12 11:08 PM Re: Jackhammer noise in wall??? NOT water hammer? [Re: emg2525]
JimTheTinkerer Online   content
" Humming Bulb "
Loc: US
A woodpecker has a distinctive "braaap" sound like a
tiny machine gun or engraving pen. Pipes go BANG....BANG..
The nature of the noise might lead you somewhere.
--Chill Y'all--(is back!)
#703667 - 02/01/12 05:06 AM Re: Jackhammer noise in wall??? NOT water hammer? [Re: emg2525]
Could it be a loose piece of soffit, or siding, blowing/rattling in the wind? Or the louvers on a whole house fan exhaust?
#703668 - 02/01/12 05:21 AM Re: Jackhammer noise in wall??? NOT water hammer? [Re: Anonymous]
shooter Offline
Loc: St. Louis, MO USA
I'm not feeling the woodpecker scenario since you said it happens most frequently at night. Do you have a heat pump located outside the bedroom wall? A common practice on new homes around here is to mount the AC or heat pump unit on a metal bracket suspended from the foundation rather than setting it on a concrete pad. It allows the HVAC guys to do their job prior to finish grading. If you have this type of setup, compressor start-up noises might be telegraphed through the metal mounting bracket and be picked in the wall or duct work. Just a thought... Good luck.
#703694 - 02/01/12 10:12 AM Re: Jackhammer noise in wall??? NOT water hammer? [Re: shooter]
FredDwyer Offline
Woodpecker or not, a look into the attic when the noise is present would be my next move.
Fred
#703699 - 02/01/12 11:32 AM Re: Jackhammer noise in wall??? NOT water hammer? [Re: FredDwyer]
Yep. Maybe a raccoon or squirrel(s)...
