0 registered (), 16 Guests and 2 Spiders online.
Page 2 of 3 < 1 2 3 >
#698454 - 12/28/11 04:51 PM Re: Hammerdrill trouble [Re: Punky]
grizzly Offline
Loc: penna.
#698455 - 12/28/11 05:13 PM Re: Hammerdrill trouble [Re: wsommariva]
Loc: Springville, NY
yikes...that would be a downgrade...
and with sears stores closing nearby, a poor purchasing decision
Bupkis mit Kuduchas!
#698457 - 12/28/11 05:37 PM Re: Hammerdrill trouble [Re: Punky]
grizzly Offline
Loc: penna.
...myself, i prefer electric in a hammer drill. whistle
#698460 - 12/28/11 05:50 PM Re: Hammerdrill trouble [Re: grizzly]
wsommariva Offline
Loc: Northern NJ
No I only tightened in the one position. I'll tighten in all three next week when the new bits arrive.
I certainly ask enough questions... I was never good at spelling....
#698475 - 12/28/11 10:16 PM Re: Hammerdrill trouble [Re: wsommariva]
My 120v. Makita hammerdrill has a keyless chuck and I don't recall ever having a problem with it. I think most of my percussion bits are smooth shanked, though, one or two of them have a flat on one side.
#698482 - 12/29/11 01:58 AM Re: Hammerdrill trouble [Re: mommapup.]
Originally Posted By: bozodog
You can also try tightening the chuck in all three positions. (if you don't have already have that habit)
Yep. Normally a requirement to keeping keyed chucks tight on bits, especially with a worn chuck.
#698497 - 12/29/11 07:22 AM Re: Hammerdrill trouble [Re: wsommariva]
Grind a flat or 2 on your existing bits where they go in the chuck. Tighten all 3 holes.
BTDT...worked fine.
HTH....notnew...
#698499 - 12/29/11 07:26 AM Re: Hammerdrill trouble [Re: notnew2diy]
wsommariva Offline
Loc: Northern NJ
I'll try those two things tomorrow on my old bit thanks
#698525 - 12/29/11 11:15 AM Re: Hammerdrill trouble [Re: wsommariva]
My tapcon bits have a flat spot and they don't slip. Hard to tell what type shank the ones I ordered look like, but I hope that they work.
Tapcon bits are designed for hammer drills. Its not just the part that goes into the chuck but the tip and design of the whole bit is different too. Cheap masonary bits are not designed for hammer drills, the package will probably say something like "rotary only", or "not for hammer drills".
#698526 - 12/29/11 11:17 AM Re: Hammerdrill trouble [Re: MCA]
wsommariva Offline
Loc: Northern NJ
I bought 4 new bits that are for hammer drills, I'm hoping I'm all set, thanks
