#698060 - 12/25/11 06:21 AM Why use combo meter socket/breaker panel?
peleliu Offline
Loc: Winston-Salem, NC
A house of a friend has a 200a combo meter socket/breaker panel mounted to the basement exterior wall. I am trying to figure out why this was done instead of the traditional back-to-back arrangement with the meter socket outside and the breaker panel on the interior basement wall. It seems to me that breakers should be inside and not exposed to the weather.
In what situations are combo panels used? Perhaps houses with crawl spaces or houses without a garage to mount the breaker panel inside?
Does the electrical code address the use of combo panels?
The house is being rewired because of tornado damage and I'm thinking that it should be changed to the back-to-back arrangement. The electrician is about to start and I want to make sure it is being done properly.
#698069 - 12/25/11 08:41 AM Re: Why use combo meter socket/breaker panel? [Re: peleliu]
Loc: muttonville,ny
Some areas it is all you find. Some areas all are back to back as you are used to. In one area here we put the panel in the center of the basement. Then Meter out side garage. Power piped under the floor and up into panel in basement.
The code just requires the main disconnect be outside OR nearest point of entrance as possible.
“I always get to where I’m going by walking away from where I’ve been.”
— Winnie the Pooh
#698072 - 12/25/11 09:14 AM Re: Why use combo meter socket/breaker panel? [Re: peleliu]
SpeedyPetey Offline
Loc: NY State
In some areas it is code required to have an outside disconnect. In some areas the whole panel itself is outside, like crazy California.
The other time it would be required is if the panel is too far into the structure, as Ceis mentioned.
Signature starts here:
#698075 - 12/25/11 09:40 AM Re: Why use combo meter socket/breaker panel? [Re: code_ceis]
peleliu Offline
Why would it go outside in the weather if there is a basement where it is protected and you don't have to go outside to get to a breaker?
Is it cheaper/quicker for the installer?
#698078 - 12/25/11 10:25 AM Re: Why use combo meter socket/breaker panel? [Re: peleliu]
Loc: muttonville,ny
Not necessarily. As Pete mentioned some areas require it outside as per fire code. Allows first responders to turn off power from outside. Some people will build as they are accustomed with not by local customs. FEMA is now requiring panels on first floor not in basements in flood areas.
— Winnie the Pooh
#698112 - 12/25/11 09:29 PM Re: Why use combo meter socket/breaker panel? [Re: SpeedyPetey]
captain150 Offline
Loc: Canada
When I was there that's all I saw. Confused the hell out of me, took me forever to find the panel.
It seems like, well, kind of a dumb thing to do. The panel I looked at wasn't more than 5 years old and was just packed with dust (desert area). So...I don't get it. Guys, just put the panel inside the house...
In Canada, my panel is on the opposite side as the meter. So the service wires come in underground, go up the exterior wall to the meter, and then back down underground, all the way around the house underground, and down into the basement on the other side. I think that's pretty stupid too.
#698115 - 12/25/11 09:47 PM Re: Why use combo meter socket/breaker panel? [Re: captain150]
Loc: muttonville,ny
We do not regulate STUPID.
"Stupid is as stupid does." Said Mr. Gump
— Winnie the Pooh
#698344 - 12/27/11 06:45 PM Re: Why use combo meter socket/breaker panel? [Re: peleliu]
All-in-one panels are used because they are cheaper since its all one box and they don't need a feeder between the two. A seperate outside main and an inside panel could be used where an outside main is required. Around here all panels are inside, usually the main is in the inside panel, some local codes say maximum 5 feet between the meter and inside main panel. There are a few local codes here that require a main disconnect outside.
#698505 - 12/29/11 10:39 AM Re: Why use combo meter socket/breaker panel? [Re: code_ceis]
ChrisB71 Offline
" Silver Eagle "
With the length the SE cable is run from the meter base to the can does that mean there has to be a seperate disconnect, effectively turning the main panel into a sub-panel?
One electrician I know says that if the main panel is > 3' from where the SE cable enters the house, a disconnect is required in between. i.e., if the panel is located 10' from the outside wall, a disconnect is required no further than the 3' mark.
Is that code, local code, just his idea or am I mis-interpreting what he said?
Regards,
Chris
#698508 - 12/29/11 10:50 AM Re: Why use combo meter socket/breaker panel? [Re: code_ceis]
ChrisB71 Offline
" Silver Eagle "
The first responders reasoning makes sense, but in this area (NE Pa) the panel being outside would probably cause them to need to come to our homes in the first place...
I think it's interesting that the FEMA would require them on the first floor in flood zones. It's not a terrible idea from a getting flooded standpoint, but if they push for that people will start wanting to put the panels in closets as panels aren't really decorative. What kind of problems will that cause? If I recall correctly, the code is pretty specific about panels and closets.
Do you think that's a good idea?
Regards,
Chris
