#697902 - 12/23/11 09:26 AM Liftmaster garage door opener trouble Model 1255
wsommariva Offline
Loc: Northern NJ
Hi everyone. My drive gear failed so I replaced it. When I was reinstalling the logic board with the unit plugged in, I fried it. So I bought a new logic board and installed it. Now the motor hums and the door does not move. Diagnostic says maybe a bad RPM sensor. Question is think the RPM sensor was also fried when the logic board was? Liftmaster customer service is closed for the holidays.
I certainly ask enough questions...
I was never good at spelling....
#697904 - 12/23/11 09:51 AM Re: Liftmaster garage door opener trouble Model 1255 [Re: wsommariva]
Holmesuser01 Offline
Loc: Asheville, NC USA
If the motor hums, but does not turn, try turning it by hand. If you can easily do this, replace the motor capacitor.
I worked on alot of Chamberlain GDO's when I worked at Sears. Lots of logic boards, lots of stripped gears, and only one bad motor. Impressive!
Oh yeah, You might need to cycle the opener. You should disconnect the drive chain and let it run from one end of travel to the other.
Edited by Holmesuser01 (12/23/11 09:53 AM)
#697909 - 12/23/11 11:01 AM Re: Liftmaster garage door opener trouble Model 1255 [Re: Holmesuser01]
wsommariva Offline
Loc: Northern NJ
Capacitor it was!!! Thanks very very much!!!! I actually reversed the wiring when I re-installed it after changing the gear drive!!!!
#713494 - 04/17/12 07:12 PM Re: Liftmaster garage door opener trouble Model 1255 [Re: wsommariva]
I need some help I replace the gears in a
1255lm now it only goes 12 in. and then goes back please help
#713520 - 04/17/12 11:17 PM Re: Liftmaster garage door opener trouble Model 1255 [Re: wsommariva]
If you order the replacement gear kit it comes with step by step instructions how to change them.
#755764 - 05/20/13 04:28 PM Re: Liftmaster garage door opener trouble Model 1255 [Re: wsommariva]
How to I test an rpm sensor?
