1 registered (Bob_Fleming), 30 Guests and 1 Spider online.
Page 2 of 4 < 1 2 3 4 >
#697612 - 12/21/11 01:33 PM Re: Sear chainsaw 20cc oil mix question [Re: jdevlin]
You can get both synthetic and conventional oils for water or air cooled. You will need, for that outboard, a water cooled 2 cycle engine oil. It will probably include the picture of an outboard on it.
I believe (CC can advise more properly) you want an oil rated TCW3.
#697620 - 12/21/11 01:58 PM Re: Sear chainsaw 20cc oil mix question [Re: jdevlin]
Got'cha! Thanks again.
(sorry for hijacking this thread)
#697670 - 12/21/11 06:56 PM Re: Sear chainsaw 20cc oil mix question [Re: jdevlin]
The stuff I'm currently using is OMC 2 cycle for lawn mowers. I got a few new unopened bottles from work that were being disposed of do to the machines being gone.
I also have a large stock of 50:1 Motomaster snowmobile oil. It says for low temperatures and meets API TC specs and not to use it outboard motors.
#697699 - 12/22/11 05:12 AM Re: Sear chainsaw 20cc oil mix question [Re: jdevlin]
Your oils, Jdevlin, are for Aircooled. Just what you need. TC is "two cycle". TWC is two cycle water cooled.
#697701 - 12/22/11 05:28 AM Re: Sear chainsaw 20cc oil mix question [Re: JasonB]
Checked last night. The oil we're using now is Marine 2 cyl., but TheBrit said we just started using it on the last tankful. Oh well, new plugs for the spring and we'll give'er a go.
#697720 - 12/22/11 08:13 AM Re: Sear chainsaw 20cc oil mix question [Re: jdevlin]
Jason pretty well summed things up.
I use three oils...
First, the TC-W3 for all marine applications.
Second, both mineral and synthetic oil specifically for sleds - these have low temp (-40F) capabilities. I use both as one of my sleds needs the synthetic, the other four get the "cheap stuff".
Third, whatever I can find for regular 2-strokes. The TC class IIRC.
But the key reason I asked above what oil you were using was because the various applications (marine, sled, utility) all should use different oils...
#697732 - 12/22/11 08:51 AM Re: Sear chainsaw 20cc oil mix question [Re: CabinConnection]
UhOhh... Does that mean our newish 2 cyl snow thrower should have a "cold weather" mix?
Jeesch, methinks we have too many machines. smile
#697735 - 12/22/11 09:05 AM Re: Sear chainsaw 20cc oil mix question [Re: jdevlin]
Your snowthrower will be fine with utility 2 cycle oil. The difference between a 5hp 2 cycle blower engine and a 50hp sled engine are vast.
#697737 - 12/22/11 09:13 AM Re: Sear chainsaw 20cc oil mix question [Re: JasonB]
Agree.
#697744 - 12/22/11 09:36 AM Re: Sear chainsaw 20cc oil mix question [Re: CabinConnection]
Phew! Thanks guys.
Moderator:  Bob_Q, Ernie
