#691884 - 11/06/11 04:42 PM Maytag washer won't drain
edcclrt Offline
Maytag washing machine runs through it's cycle but it will not drain. At the end of the complete washing cycle there still is water in tub. I took off front panel and watched it go through its cycle. I could see the pump working. I tightened the belt on the pump just to make sure, but I can see the water flowing through the pump. But at the end of the cycle there is still water in the tub.
Edited by edcclrt (11/06/11 06:56 PM)
#691908 - 11/06/11 09:31 PM Re: Maytag washer won't drain [Re: edcclrt]
Model#?
http://www.applianceaid.com/model.html Some model# helps.
Checked the drain hose?....not kinked, nothing caught in it?
#692007 - 11/07/11 03:28 PM Re: Maytag washer won't drain [Re: jeff1]
Holmesuser01 Offline
Loc: Asheville, NC USA
Some older Maytags depend on looseness of the belts to get the tub spinning.
I used to have a big beautiful Iowa built Maytag that liked to hide a sock now and then in the drain line above the pump.
How I miss that machine. Heavy, and very well built.
#692031 - 11/07/11 06:28 PM Re: Maytag washer won't drain [Re: Holmesuser01]
edcclrt Offline
Well there it is a sock. Stuck in the drain plug coming out of the tub. Didn't see it the first time I checked the hoses to see if they were clogged. Took off the hose and put my finger in the nipple sticking out of the bottom of the tub and there it is a sock. Thanks for all the suggestions. And my 21 year old Maytag washer ( and dryer ) keep on going.
#692051 - 11/07/11 09:02 PM Re: Maytag washer won't drain [Re: edcclrt]
Thankx for the update!
How to prevent...
http://www.applianceaid.com/laundrybag.html
#692072 - 11/08/11 05:39 AM Re: Maytag washer won't drain [Re: jeff1]
Huh.
Never heard of this kind of thing.
Once AGAIN!
Learn sumpth'n new every day. smile
#692202 - 11/08/11 08:06 PM Re: Maytag washer won't drain [Re: CabinConnection]
captain150 Offline
Loc: Canada
Originally Posted By: CabinConnection
Huh.
Once AGAIN!
Yeah, the sock gets caught between the inner and outer tub and makes its way down and ends up in the pump suction hose. Some washers are more vulnerable than others, I think.
#692234 - 11/09/11 08:15 AM Re: Maytag washer won't drain [Re: captain150]
Yup!
#692418 - 11/10/11 06:27 PM Re: Maytag washer won't drain [Re: jeff1]
I sure do miss my big old Maytag. Other than new belts after 13 years, it never did anything wrong, but eat a sock or two.
#692937 - 11/15/11 11:31 AM Re: Maytag washer won't drain [Re: edcclrt]
bristolbaby Offline
Loc: CT
I keep losing my toddler's socks and recently lost a fleece mitten. I wonder if that's where they went! Thanks for the tip!
