7 registered (JasonB, kickintile, Able_Dog, bilvihur, 3 invisible), 48 Guests and 1 Spider online.
Page 13 of 15 < 1 2 ... 11 12 13 14 15 >
#690122 - 10/25/11 01:21 PM Re: How to correct bowed walls on completed garage? [Re: KingRay]
WOW.....you posted those as I was typing a reply........
I'm bumping my "Ive got $20.." to "Ive got $50... !!!!!!!!!!! grin
#690143 - 10/25/11 03:57 PM Re: How to correct bowed walls on completed garage? [Re: KingRay]
Loc: Springville, NY
i'm still lurking here but judging from the last 2 pics it appears that the bow is uniform from one side to the other. As said before, like something leaned on it, or it has settled in one direction, or prevailing winds have pushed it on that direction.
IF the above is to be assumed - that it shifted over time, then the slack and space will be available in the miscellaneous boards and sheets - the spaces were made as it shifted - and it could be pulled back to straight gently over time.
IF the structure was built in that manner then nothing short of destruction/reconstruction will straighten it.
Bupkis mit Kuduchas!
#690144 - 10/25/11 04:02 PM Re: How to correct bowed walls on completed garage? [Re: BillJeffy]
Originally Posted By: BillJeffy
Originally Posted By: CabinConnection
OK... I give up...
You've avoided explaining your "use rebar to pull it back" recommendation a number of times. KingRay's already had it with suggestions and opinions here, and I certainly can't blame him for copping an attitude.
You avoided the 'Yes or No' answer, so we're even !
Guess I was so crabby about your not answering a direct question, I didn't even realize you were asking me what my opinion was. Seems I was pretty clear in all of my posts. I've said all along that if the sheets were nailed onto the trusses when the bow was in place, that I didn't agree you could pull and keep it in the right place. Clear 'nuff? wink
And FWIW... Never heard of welding up rebar & using turnbuckles to pull a wall like this. It'd be cables / come-a-longs and wood to hold it, IF it came to the right spot 'round here.
KR - I think everyone who posted was trying to help. Just different opinions on how.
#690146 - 10/25/11 04:10 PM Re: How to correct bowed walls on completed garage? [Re: KingRay]
our barn has heavy steel rods in the corners to help hold them straight - exactly like rebar but without the ribs. probably the steel used to wrap silo staves.
#690243 - 10/26/11 08:02 AM Re: How to correct bowed walls on completed garage? [Re: KingRay]
So KingRay...
Does the header above the garage door got a case of the sags as well?
Just wondering...
wink
#690371 - 10/26/11 04:32 PM Re: How to correct bowed walls on completed garage? [Re: KingRay]
Able_Dog Online   content
Loc: N Georgia
Can you put a string line on the front outside or on the back inside and determine the exact amount that it's bowed?
Also, how are the trusses attached to the top plate? Are ther hurricane ties or metal straps?
I think I can make a suggestion on how to "fix" that without removing all the plywood and save you all the effort of removing the plywood and no, I don't think it can be winched back.
Have you decided on a plan?
#690383 - 10/26/11 05:23 PM Re: How to correct bowed walls on completed garage? [Re: Able_Dog]
KingRay Offline
Loc: Wichita, KS
There is no sag to speak of. Just looks like that in the photo. The bow is all that is there. Its between 4 and 5" . I have measured this 3 times now in many locations.
The rafters are toe nailed. All that is required here.
No plan, Just reading up on comments until I get some help and then we will tackle it however seems to be practical. really just waiting for a good stretch of no rain and some decent weather. Its starting to get colder now so we need to get on it. I dont wnt to be out there in the subfreezing temps, Nothing I hate worse. well 108 on a roof insulation deal this summer might have been worse. lol
KingRay
#690385 - 10/26/11 05:31 PM Re: How to correct bowed walls on completed garage? [Re: KingRay]
Ho-kay... Just looks like it... Got it.
And yeah, insulating in the hot/humid part of summer kinda SUCKS.
#690387 - 10/26/11 05:35 PM Re: How to correct bowed walls on completed garage? [Re: KingRay]
Loc: N Georgia
Are you going to try to winch it into alignment?
#690390 - 10/26/11 05:47 PM Re: How to correct bowed walls on completed garage? [Re: CabinConnection]
Loc: N Georgia
Is that front 32' across? Sure doesn't look like it. Photos can be misleading.
This column for example has a notch of about 11-1/4 inches, looks a lot more than that doesn't it?
