2 registered (CabinConnection, Able_Dog), 17 Guests and 1 Spider online.
#687658 - 10/08/11 01:22 PM Cannot get rid of this weedy stuff
rfm3 Offline
Everybody Loves Ray
Not sure what this is. It is like a creeping cover of sorts, with a vine like ability to just invade the yard. Have had it every year and nothing seems to get rid of it. Probably too late now to do much, even roundup killed the grass more than this stuff...
#687660 - 10/08/11 01:39 PM Re: Cannot get rid of this weedy stuff [Re: rfm3]
Oh, oh... ask Liz! It's creeping charlie, and really tough to get rid of.
#687661 - 10/08/11 01:45 PM Re: Cannot get rid of this weedy stuff [Re: rfm3]
Ernie Offline
Shaman
Loc: Southern ,California
** Quote ***
Ground Ivy
•Scalloped, round leaves up to an inch in diameter.
•Ground ivy has square stems.
•Leaves grow in pairs positioned opposite each other on the stem.
•Grows in shade and full sun.
•Can be difficult to control.
(Photo used with permission: flowers.vg)
Weed Identification
Ground ivy, sometimes called ``Creeping Charlie`` crazy wink
is a perennial weed that can grow very quickly in thin turf.
It was once planted as a shade ground cover, but because of its aggressive nature,
is now considered a pest. Ground ivy spreads by above ground, laterally growing stems,
called stolons. These stolons can outpace the growth of turfgrass.
This is especially true in shaded areas. However, in lawns with thin turf,
ground ivy will grow equally well in both shade or full sun.
For positive weed identification, look for leaves growing on a long petiole,
positioned opposite each other on square stems. In the spring you can see small blue flowers
in the shape of a funnel which will help with weed identification.
Ground ivy is similar in appearance and sometimes mistaken for another lawn weed called “common mallow”.
Cultural Practices
Ground ivy is difficult to remove without the use of herbicides.
Unless the entire runner is removed, it will re-establish. The runners root at the nodes,
so if you break the runner at any point, it will continue to grow. If your neighbors have
it in their yard, it will only be a matter of time before it spreads into yours.
If possible, encourage your neighbors to begin controlling it.
Herbicide Use
Many herbicides are labeled for ground ivy. It will generally need several applications
spaced approximately 4 weeks apart for best control. Ground ivy behaves as a cool season perennial,
so the best time to spray is when it is actively growing in the spring and fall.
Persistence is the key.
Use products containing Dicamba plus 2,4-D or triple herbicide products.
If your neighbors are unwilling to work with you in controlling this pest,
then a barrier may be needed to keep it out of your yard.
` And Happy Belated ( Sept 23rd ) Birthday
to You Liz ! smile
morrisdancer is over their Private Topic limit
````` Amazing Grace ``````
#687668 - 10/08/11 03:10 PM Re: Cannot get rid of this weedy stuff [Re: Ernie]
rfm3 Offline
Everybody Loves Ray
yea creepin charlie is one name I have heard...wife calls it California crawl...either way, I can pull this out and have nothing left and then it is back...neighbours? Bah! I will blast it if possible and neighbour will not be bothered..too much...
so fall is a good time then...good, time to load up and let loose the dogs of weed war
#687669 - 10/08/11 03:16 PM Re: Cannot get rid of this weedy stuff [Re: rfm3]
Ernie Offline
Shaman
As Boz said..
Liz might have some good suggestions on
to how to handle the California `crawl` crazy
Never heard it called that before.. confused
Hummm... California `creep``` Now ! that I have heard
``before.``. whistle grin
#687670 - 10/08/11 03:21 PM Re: Cannot get rid of this weedy stuff [Re: Ernie]
rfm3 Offline
Everybody Loves Ray
now now do not put words in my mouth there pardner...this stuff will not go away...the last time I went around with that darn roundup stuff, it killed the grass and left the weed. It seems this year has been worse than usual...if I can get some of it done in fall and resume in spring, so be it...I want to put my winterizer stuff on this year..missed out last year...
#687673 - 10/08/11 03:28 PM Re: Cannot get rid of this weedy stuff [Re: rfm3]
Ernie Offline
Shaman
~~` Now now now.. would be a could time
to get down on those "weeds " laugh
Heck when I started trying to go green..
and save a little water for the planet ?
My grass died and the weeds have gone crazy... crazy
~~~~~ " Sow " I just mow them down... more often ! than
I had to `` with the nice green lawn` of grass....
~~~~ What was I thinking ?.. confused
``````p'rolly wasn't.. whistle grin
#687688 - 10/08/11 04:50 PM Re: Cannot get rid of this weedy stuff [Re: rfm3]
rfm3 Offline
Everybody Loves Ray
I do not mind green...but when the darn stuff invades the flowers and veggies....well the wife is not happy...
#687701 - 10/09/11 12:04 AM Re: Cannot get rid of this weedy stuff [Re: rfm3]
morrisdancer Offline
Loc: Michigan
Ohyahhhh, Creeping Charlie, California version, Northern version, all the same nasty stuff. That stuff even grows under the snow!
The only method that worked for me is to dig it up (use the claw tool thingy so you get most of the roots) and do NOT put it in the compost pile. Sneak it in your garbage (I know, I know, butt....) Be vigilant and it will be eradicated! I was so infested with it and after digging and pitching relentlessly for an entire season, the next year, it was down likely 75%. Now its controllable. *knocks wood*
Oh yeah, there are some who say Roundup or Weed Be Gone Max works on Creeping Charlie, but I had no luck with it. Those chemicals acted like a nutritious, hardy meal.
(Thanks for the Birthday wishes!!)
Liz
Thanks, Chris and Ernie!
#687702 - 10/09/11 02:51 AM Re: Cannot get rid of this weedy stuff [Re: morrisdancer]
Originally Posted By: morrisdancer
Oh yeah, there are some who say... ...Weed Be Gone Max works on Creeping Charlie, but I had no luck with it.
I'm one. Worked for me 100% of the time. I use the concentrate, put it in my sprayer, and apply at the "strong" dose ratio.
Roundup is an indiscriminate killer... It kills everything. Why would you use it for creeping charlie and not expect it to kill everything you spray it on as well as anything down wind???
(Enter thingy that represents total confuzzlement here.)
