1 registered (1 invisible), 160 Guests and 3 Spiders online.
#665802 - 05/11/11 06:57 PM 208v. vs. 240v. vs. 220v.
figaro Offline
Loc: Des Moines, Iowa
I am looking at a steam generator for a shower. It talks about 208v. or 240v. Is the 208v a european voltage?
Also, I hear most people refer to 220v but here they talk about 240v. Aren't ovens, dryers, etc. 220v.? What's the difference?
Thanks
#665803 - 05/11/11 07:04 PM Re: 208v. vs. 240v. vs. 220v. [Re: figaro]
Loc: muttonville,ny
220 and 240 are the same just different names both are from a single phase transformer. 208 is a single phase tap of a 3 phase normally.
" Life is like a piano....
#665804 - 05/11/11 07:21 PM Re: 208v. vs. 240v. vs. 220v. [Re: code_ceis]
figaro Offline
"208v is a single phase tap of a 3 phase normally"
In laymans terms??????????
Thanks
#665805 - 05/11/11 07:34 PM Re: 208v. vs. 240v. vs. 220v. [Re: figaro]
Gizmologist09 Offline
Loc: Palmdale, California USA
208v is found in industrial settings as well as 277v and 480 volt taps. Industrial installations usually have a 480 volt feed from the power company and the facility then has a step down transformer that delivers 120 volts for offices etc and 2777 for lighting. Residential power in the US will be 220-240 between the phase legs in your panel. The device you are looking at will likely have a tap for power listed for 208 and another for 240. Just leave the 208 alone and use the 240volt taps.
#665806 - 05/11/11 07:52 PM Re: 208v. vs. 240v. vs. 220v. [Re: Gizmologist09]
figaro Offline
THANKS!!!!!!!!!!!!!!!!!!
#665807 - 05/11/11 10:52 PM Re: 208v. vs. 240v. vs. 220v. [Re: figaro]
120/240 (some say 110/220, 115/230/125/250) are from a split phase service as most houses have.
120/208 is a 3 phase Y system as found in commercial buildings. Industrial buildings may have a 277/480 3 phase Y as mentioned. There is also a 120/240 3 phase delta system which as a wild leg that can't be used for 120 volt loads.
Some apartment buildings are fed by a 120/208 system and each unit may have a single phase panel but it will be 208 instead of 240 because it was derived from a 120/208 3 phase system. A single house in a commercial area may have a 120/208 service even though there is only a single phase panel at the residence.
#665808 - 05/12/11 12:07 AM Re: 208v. vs. 240v. vs. 220v. [Re: MCA]
I didn't want to confuse the issue. I have never run into a residential 208 as that would pose a LOT of problems.
Edited by Gizmologist09 (05/12/11 12:09 AM)
#665809 - 05/12/11 12:17 PM Re: 208v. vs. 240v. vs. 220v. [Re: Gizmologist09]
Its somewhat common in larger apartment buildings (although the panel in the individual unit will probably be a single phase panel). Electric stoves and dryers will take longer to heat. The problem may be with a motor. An air cond. unit that is designed for 240 may have a problem with 208. If 10% variance from the voltage rating is considered acceptable then if it was rated for 230 volts then 230-(.10x230)=207. But after voltage drop the voltage may end up being under 208. Usually the acceptable variance is used to absorb voltage drop. A lot of commercial equipment is can be connected to 208 or 240. While most commercial buildings are 3 phase most newer ones are Y systems producing 208 but some older ones are delta systems producing 240.
277 volt lighting is interesting. 277 is the phase to neutral from a 480 Y service. When someone who know residential wiring doesn't know there are differences in non-residential systems and wonders why there is over 240 volts on a circuit and is surprised to hear that its supposed to be 277.
For those wondering why a nominal voltage numbers include 208 and 277 it has to do with the angles of the transformer windings and can be explained with triginometry.
