5 registered (Able_Dog, jhimer, 3 invisible), 50 Guests and 3 Spiders online.
Page 2 of 3 < 1 2 3 >
#574294 - 11/02/09 04:04 PM Re: Fridge [Re: jeff1]
yardmaster Offline
the original could have been a white block relay/overload...
Correct...the newer/replacement ones are seperate.
Still check for 110 volts at the 2 wires, still shake the old to see if it rattles.
gotchya...this is my relay (which looks different from the newer versions):
and shaking it...i do hear a slight rattle...
I also check the cap at different RX settings...at 10K i did get movement...somtimes...
#574295 - 11/02/09 10:04 PM Re: Fridge [Re: yardmaster]
The seperate ones are the kit an appliance tech would likely use...there still is a block verion more like the original style available...
Start-relay combination
Shouldn't.
It is likely ok...these are small 10-16UF.
#574296 - 11/03/09 11:57 AM Re: Fridge [Re: jeff1]
yardmaster Offline
Shouldn't.
Like a lightbulb...
Figures...none of my local suppliers carries this in stock. So ordered from this place... shipping is 2-7 days...lets hope its on the lower end.
thanks for keeping me from buying the wrong part!
#574297 - 11/03/09 06:10 PM Re: Fridge [Re: yardmaster]
Let us know how the repair goes.
#574298 - 11/04/09 07:22 AM Re: Fridge [Re: jeff1]
yardmaster Offline
Will do.
#574299 - 11/06/09 08:49 PM Re: Fridge [Re: yardmaster]
yardmaster Offline
Part arrived today...got it in. Filled an ice cube tray with water...seems to be freezing up.
Not gonna put anything else in fridge until tomorrow...just to make sure...
#574300 - 11/07/09 07:16 AM Re: Fridge [Re: yardmaster]
Good! Thankx for the update
#574301 - 11/07/09 09:30 AM Re: Fridge [Re: jeff1]
yardmaster Offline
The next morning: All is right in our world again!
Ya dont realize how important a fridge is until you dont have one.
Thanks again.
#574302 - 11/07/09 09:40 AM Re: Fridge [Re: yardmaster]
So true!
#574303 - 11/08/09 04:23 PM Re: Fridge [Re: yardmaster]
yardmaster Offline
jiggling the condenser i hear the "knocking" we have heard.
and now the follow up question....should i be concerned about this knocking? It still does it....without us jiggling it...
