3 registered (twoshoes, 2 invisible), 147 Guests and 3 Spiders online.
#489705 - 09/29/08 11:46 AM 12 Gal Shop Vac won't turn on...
lj4174 Offline
Loc: Reading, PA
...is this worth pulling apart and trying to fix it. It wasn't used all that much, but I've had it a few years. Can't see a brand name on it, other 'Shop Vac' is there anything fixable on these???
What did you think I was??? Just another pretty face...
#489706 - 09/29/08 11:56 AM Re: 12 Gal Shop Vac won't turn on... [Re: lj4174]
ShopVac is the brand name. You could check out the switch itself... and the other wiring.
#489707 - 09/29/08 12:51 PM Re: 12 Gal Shop Vac won't turn on... [Re: mommapup.]
lj4174 Offline
Loc: Reading, PA
Cool, I didn't know if there was a fuse or something in there... It's kinda nasty so I didn't want to mess with it if I didn't need to...
#489708 - 09/29/08 01:05 PM Re: 12 Gal Shop Vac won't turn on... [Re: lj4174]
Nasty could be the reason for the failure. Especially if you left water in there to cause oxidation of the switch and/or wires, shucks, even the motor... Don't get your hands dirty, just go buy a new one and keep the economy going. (jus'joking...)
#489709 - 09/29/08 01:26 PM Re: 12 Gal Shop Vac won't turn on... [Re: lj4174]
Try calling Shop-Vac. I had a motor burn out and they sent me a new motor (a whole new head) free of charge, and this was a few years after I bought it.
#489710 - 09/29/08 01:42 PM Re: 12 Gal Shop Vac won't turn on... [Re: MCA]
lj4174 Offline
Loc: Reading, PA
Nice... Nah, not nasty like that, just all dusty and stuff, you know, what you would expect to have on the inside of a shop vac. I don't think I've ever used it to suck up water, if I did it wasn't often or maybe once...
Perhaps I'll try doing this, but I do need one ASAP. I recall this working and then the next time I used it didn't. I forget why I didn't look at it then, so I may need to just bite the bullet and buy a new one. As much as I hate doing that. Wonder if my Dad has one I can... "borrow"...
#489711 - 09/29/08 02:18 PM Re: 12 Gal Shop Vac won't turn on... [Re: lj4174]
The switch and motor are all outside of the container - so they shouldn't ever get "nasty" themselves... Try taking the switch apart first and putting a jumper across it. You'll know right away if that's your problem.
New ones are not all that expensive anymore...
#489712 - 09/29/08 03:45 PM Re: 12 Gal Shop Vac won't turn on... [Re: CabinConnection]
rfm3 Offline
Loc: Guarding the West NY Border fr...
if you need one quickly, go buy a new one...and then work on the other one. I find more than one is handy...I keep one in the basement and another in the garage, saves lugging them in and out.
In fact I have a third one I use strictly only for water pickup..even has a handy dandy part that allows it to pump the water out.
We didn't start the fire
It was always burning since the world's been turning
No, we didn't light it, but we tried to fight it
#489713 - 09/29/08 04:05 PM Re: 12 Gal Shop Vac won't turn on... [Re: rfm3]
Ahhh yes...
A Handy Dandy Water Pumper-outer!
#489714 - 09/30/08 08:16 AM Re: 12 Gal Shop Vac won't turn on... [Re: CabinConnection]
rfm3 Offline
well when one has to remove water in a basement, it was handy to put the hose out the window and keep sucking up water.
