5 registered (Jeff_McMaster, Joe_Guy, kickintile, 2 invisible), 51 Guests and 2 Spiders online.
#483622 - 05/28/09 09:53 PM Re: Weedeater FL20 with Walbro WT669 Carb [Re: Blaineg]
Blaineg Offline
Loc: WI, Racine, Raymond
Well, I did everything I said I would do and thanks to you it worked great!!! I had a little trouble finding something that would work with adjusting the mixture screws but with a little creativity I managed! (I called several small engine shops and no one had a tool for the splined screws) It started on the first pull and ran great! I still adjusted a little bit but really didn't make much of a difference. I was feeling so confident that I pulled out the Leaf blower that has been giving me trouble for the last 3 year and did the same thing to that and now that runs better than it did when it was new!
One note I would suggest is that you either replace or flex (bend and role) and clean ALL the fuel lines. What I seemed to notice was that the fuel must dry out in the lines when the muchine sits for a while, and when you try running it the dried residue breaks loose and plugs the screen in the carb. flexing the line thoroughly and running carb/brake cleaner through it will clean out all the residue in the lines.(or just replace the lines)
Thanks again! You saved me a couple hundred dollars by not having to buy a new weed eater and leaf blower!
Have a great summer!!!
#483623 - 05/29/09 04:56 AM Re: Weedeater FL20 with Walbro WT669 Carb [Re: Blaineg]
Good work, Blaineg! Not that hard a job once you get in there, is it? Satisfying when successful, too!
Old fuel oxidizes and becomes a varnish on any fuel component. Not a nice varnish, but a weak, gummy, sticky, smelly tan coloured gunge.
On any small engine I work on that has varnish in all the lines, I'll usually just replace those fuel lines rather than try to clean'em. I've felt it's 5 bucks well spent. Definately, though, not something to overlook!
Good tip!
#483624 - 06/01/09 01:51 PM Re: Weedeater FL20 with Walbro WT669 Carb [Re: Blaineg]
chrislipscomb Offline
Loc: West Virginia
I did not need to remove the screws, but I have had to fine tune each time I cold-start the trimmer. It is a great feeling to adjust just a little rich and have all that extra power under load!
The LORD is my Shepherd, I shall not want.
#483625 - 08/04/09 08:40 AM Re: Weedeater FL20 with Walbro WT669 Carb [Re: chrislipscomb]
OGBrewer Offline
Loc: Hastings, MN
I found that the 'applicator straw or tube' from a can of Great Stuff spray in foam insulation works great for removing the screws, in order to grind a slot in the heads for future adjustments. It fits very snuggly onto the screw, allowing it to be backed out of the carb.
#483626 - 08/22/09 12:03 PM Re: Weedeater FL20 with Walbro WT669 Carb [Re: OGBrewer]
JoeBeck Offline
I have a weedeater featherlite that does the same thing. But my carb has only 1 screw which is plasic and orange sticking out of the carb. It is located between where the carb is marked L and H. Suggestions? Thanks
#483627 - 06/23/11 12:52 PM Re: Weedeater FL20 with Walbro WT669 Carb [Re: JasonB]
HDWildBill Offline
Loc: Georgia
Thank you so much for the info. I followed the directions and my buddy's weedeater is working like a champ!
Buy the way a blue wire connector will work to get the adjustment screws out also.
Bill
#483628 - 06/23/11 12:56 PM Re: Weedeater FL20 with Walbro WT669 Carb [Re: HDWildBill]
Good! Thanks for posting!
Moderator:  Bob_Q, Ernie
