4 registered (sportster, kickintile, RCovell, Able_Dog), 28 Guests and 1 Spider online.
Page 2 of 3 < 1 2 3 >
#482873 - 09/09/08 05:18 AM Re: can help me indentify this water softener [Re: Gary_Slusser]
AndyC Offline
Loc: Ohio
He just hung up on me saying rather than suffer my rudeness he would call someone out... We were on the phone about 20 minutes.
Above and on the phone he says this stuff is over his head, and he's right. So I offer to help him free of charge and he doesn't want to listen to what I tell him, he wants to talk when I'm talking and jump ahead instead of allowing me to tell him what to do.
At the end I mentioned taking the pin wheel off the timer so he starts to do it and I said NO, unplug the control first. He doesn't know what would happen had he moved the wheel with power to the control, I do. I waited 2-3 minutes after he hung up and I called him back, he wouldn't answer, so he's on his ungrateful own with a setting changed on his control and the meter cable out of the meter and he doesn't have the data I wrote down to give him later to change his salt dose that is currently set at 12 lbs. and should be 3 lbs.. Here and on the phone he says he thinks it regenerates too frequently but when asked he doesn't know how frequently it regenerates!
I guess he didn't see that he was being rude to me by not listening and then talking when I was talking. To me he was a regular guy in over is head, he was nervous and anxious and like thousands of others I've helped once they calm down and give me control of the conversation and then listen. Only then can we act as a team solving 'his' problem on my dime and free of charge to him.
WOW, That doesn't sound very professional of you Gary. Everyone, once in a while, has customer-relations problems and who knows whose to blame. But most professionals don't come back and continue the attck. It makes them look spiteful for not getting the sale. I think the best thing you could have done is let it go and behave well or apologize for the misunderstanding. I don't think anyone here needs to learn how you feel people are ungrateful toward you. But maybe we all learned something.
I have heard this happening before, so next time just cool down and move on. Be the professioanl you want people to believe you are.
#482874 - 09/09/08 06:48 AM Re: can help me indentify this water softener [Re: AndyC]
Clint_Robbins Offline
Andy,
Having seen many helpful, expert posts from Gary, and knowing that individuals like he describes exist and are sometimes nearly impossible to help, my GUESS is that he did the best he could in this case and just wanted to explain why he couldn't help.
I also know that you and Gary are water treatment competitors and have seen you two disagree in this forum several times. As you and Gary are fellow professionals, I think that some of your comments in this situation were unprofessional.
Clint
#482875 - 09/09/08 07:46 AM Re: can help me indentify this water softener [Re: Clint_Robbins]
e_a_g_l_e_p_i Offline
Loc: Minnesota
Clint, you are wrong about Gary. I will go into details,
first of all when he talks to you he talks down to you from the start, he barks commands and when I told him I didn't know anything about this stuff so when he asks a question I will anwser that question, not the one he is thinking in his head. For example, at one point he wanted me to pull out a cable from a hub that had a brass tip, I pulled and it wouldn't come out, I told him it won't come out. Instead of telling me I have to pull harder it sometimes takes a good pull he said " Listen are you going to trust me ot not?" " I know what I am doing, you don't" after pulling harder on my own it did come out but that could have been done but telling me to pull harder rather than telling me how great he is.
He had me swing out the control dials to look at the pins on the back, he asked me what the pin configuration was starting at "0" then 1,2,3,4,5,6 ect I told him that my pin cover had a "0" then then 4 dashes and then 10 so I told him I assume that the pins were in 0,2,4,6,8,10 he yelled at me and said that isn't what I asked you, what number holes have pins in them. He couldn't understand that when he asks for numbers and I don't see numbers, I see dashes and can only assume what number they represent.
He finally started yelling and telling me how great he was and how unknowledgable I was. it was a this point I hung up on him.
There is not bad blood between competitors here, Gary is just a jerk..
Edited by e_a_g_l_e_p_i (09/09/08 07:49 AM)
#482876 - 09/09/08 01:00 PM Re: can help me indentify this water softener [Re: e_a_g_l_e_p_i]
Gary_Slusser Offline
Loc: Wherever I park the motorhome
e_a_g_l_e_p_i You asked for help and I identified your equipment for you, the subject of this thread.
Then you said that the info on my sizing page was over your head while thousands of others have read it, understood it and used it. It's a simple math formula with detailed instructions IN ENGLISH!
Then you call me and didn't bother to ask me if it was a good time for me to spend some time with you etc., you simply launched into who you were and what the problem was, reestablishing you were in over your head blah blah blah. Which if you think about it, I didn't need to hear again because you told me here and I could figure it out for myself.
So I started to do my best to help you again, and yes, I asked you or told you or mentioned or OMG COMMANDED! you to pull the meter cable out of the meter. And you said, as you say now, it wouldn't come out. Yet in the picture above are instructions ON A RED Sticker, on your control valve, that COMMANDS, or asks you, to pull it out before opening the timer door. That's not something I'm making up, it's on your control valve. Then I told you it will come out trust me, pull it out, and you say IT won't come out!! And then you get upset with me because I didn't tell you to pull harder but you eventually did AND it came out. DUH!!
You also couldn't get the clear plastic ring in the center of the meter people dial out to rotate it... I gave up on that.
Then we get to the pin wheel... I said there were a number of steel pins sticking out from zero and then holes and asked you to tell me the number of pins from zero on. You had a tough time understanding that I wanted you to count the number of pins and then the number of holes and pins and holes and pins back to zero. You told me there were pins (and mention here) that there are dashes... I still don't know what dashes you talking about. Although I've seen hundreds of Fleck 1500, 2500 and 2510 pin wheels, I think you might mean short and long hash marks used to count each set of five pins or holes. But you weren't listening when I said to count the pins and holes but...
You eventually got around to telling me 'yes it says 2 minutes per pin and there are 5 pins, 60 holes, 5 pins, 4 holes, 2 pins. Now to this pont we have been on the phone for 20-30 minutes and this is all we have accomplished... It should have taken maybe 10 minutes to get that far.
The number of pins and holes tells me a lot of information about your control valve set up, one is the lbs of salt. And you're blabbering right along as you have been for 20-30 minutes and then say, yes, I've always thought it used too much salt... Yet you've gone on'n on about too frequent regenerations and when I asked how frequently, you said you didn' know!!!
Usually in 5-10 minutes the guy shuts up and LISTENS to me but not you. You got your feelings hurt and kept wasting my time. There's no way of you knowing but I had two other calls during our time on the phone.
So that's when you said again how rude I was and hung up.
For the last 6 years or so, I've spoken in person to an average of 4-5 guys a day, 6 days a week and sometimes on Sundays, Christmas and up to 11 PM, and I gotta tell you, you are not the norm; and I don't mean special in good way.
And although you hung up on me I called you back in a few minutes and would have hung on the phone no matter how long it took, or how difficult it was to talk to you until you were fixed up and your control was programmed correctly and you would have reaped the 9 lbs salt savings per regeneration every 1000 gals of water use. Oh well.. too bad so sad, life goes on and I wish you well.
Gary Slusser 22 yrs in water treatment and well pumps, 13 yrs helping people on the 'net.
#482877 - 09/09/08 02:53 PM Re: can help me indentify this water softener [Re: Gary_Slusser]
Loc: Minnesota
Type all you want Gary it still doesn't change how you treated me, since I posted my comments about how you treat people I have got over 10 PM's from people who have dealt with you and say the same thing I did about you.
I guess people will have to take the risk of dealing with you, I don't have to any more.
You are a legend in your own mind..
#482878 - 09/09/08 08:53 PM Re: can help me indentify this water softener [Re: e_a_g_l_e_p_i]
I'm glad I could help you find someone to whine with and sooth your hurt feelings.
#482879 - 09/09/08 11:55 PM Re: can help me indentify this water softener [Re: e_a_g_l_e_p_i]
matt1 Offline
Edited by Ernie (09/11/08 05:46 AM)
#482880 - 09/10/08 07:10 AM Re: can help me indentify this water softener [Re: matt1]
Loc: Minnesota
I was able to get my settings correct... It was as simple as setting the clear wheel setting of 10 to the white dot.
I didn't have to take the whole softener apart to do this either ???? I guess someone who knows how to talk to someone can help anyone huh?
#482881 - 09/10/08 07:14 AM Re: can help me indentify this water softener [Re: e_a_g_l_e_p_i]
I'm sure many of us innocent bystanders are happy you got it resolved.
#482882 - 09/10/08 08:56 AM Re: can help me indentify this water softener [Re: e_a_g_l_e_p_i]
Ron, you can complain about my "rudeness" etc. but it's a mistake to question my knowledge of setting the programming of a mechanical metered Fleck 2510 on a 1.0 cuft 6-7 yr old softener.
BTW, setting that one setting to 10 is not the same as "getting your settings correct". The 1 I told you to set it to is correct but your salt dose is incorrect for 1, and probably for 10 too.
Show us the math to prove a setting of 10,000 gallons. Did he calculate a 24 hr reserve capacity which is required with your type of control valve, and if so, how many gallons?
Otherwise enjoy your false sense of accomplishment. Eventually you will find that your softener will allow hard water through it. Later you'll probably find that this 10 has ruined your resin.
Then get back to him and follow his directions again and see how you do. Just know that he'll be wrong until eventually you'll have to "take the whole softener apart" to set the number of pin wheel pins and holes correctly. I'll bet he doesn't know what to set them to, or he'd be doing it now.
Matt1, thank you.
