#45493 - 09/19/03 04:43 PM Garage door openers current draw
amc12 Offline
I plan on rewiring my garage. I plan on having three wall outlets on a gfi line and "possibly" branch to the two garage door openers from the non-gfi side of the gfi outlet. I have no special (large)current draw in the garage other than the openers. Would I be much better off running a detecated line for the openers? I have really no idea how many amps they draw on the average. It would be alot a work to do this extra line, but I want ot do it the standard practice way, whatever that would be. Thank you in advance.
Regards,
amc12
#45494 - 09/19/03 04:58 PM Re: Garage door openers current draw
ernietempleton Offline
Denis B
hi
Motors are best on their very own circuit.
To properly size the ciorcuit ,you need to find out the amp draw of each motor.
ernie
ernietempleton aka denisb , ernie ,'bonded' , has been banned from this forum ...for good reason!
#45495 - 09/19/03 08:09 PM Re: Garage door openers current draw
Arnold Offline
Helpful Electrician
Loc: United States
My 1/2 HP Craftsman Garage Door Opener uses 5.0 amps. Your mileage may vary. It's easy to find out. It's written right on the side of the opener.
#45496 - 09/20/03 10:34 AM Re: Garage door openers current draw
amc12 Offline
Thanx Ernie and Arnold. Like I said I am buying two new openers but wanted to put the wiring in first. Just from what you said and a little reseach I think a 20 amp 12ga detecated line will be more than enough for two openers.
regards,
amc12
