3 registered (wgander, captain150, morrisdancer), 58 Guests and 2 Spiders online.
#341965 - 01/12/07 03:02 PM Extending SIRIUS Antenna
buzzard86 Offline
Not sure if this is more appropriate for the computer or electical sections. Thought I'd try here first. Anybody know if I can splice something in to extend my Sirius antenna? I'm using the home kit but can't get the antenna far enough from the house to get a good signal from the satellite. Can I splice in some wire to move the antenna further from the house? If so, what kind of wire is best? Thanks.
JIM
#341966 - 01/13/07 12:48 PM Re: Extending SIRIUS Antenna [Re: buzzard86]
JimTheTinkerer Offline
" Humming Bulb "
Loc: US
A splice to the cable has two issues:
--without proper connectors installed, signal is
lost from the disruption of the cable/wire/cable
--losses build up with distance: the current cable
is whittled down for just the length you have
(economic considerations)
An longer run needs thicker or pricier lower-loss cable,
nice connectors, and ocaisionally, an amplifier
at the antenna end.
Some stuff made for the job:
http://www.sirius.com/servlet/ContentSer...d=1128803463598
Leaving out extra connectors saves expense. At that
length, most of the money is in the cable itself.
On the West US coast, you will have a bit more signal
to work with than the East coast.
Moderator:  Ernie, saugen48
