6 registered (JasonB, 5 invisible), 53 Guests and 1 Spider online.
Page 3 of 5 < 1 2 3 4 5 >
#311509 - 09/20/06 06:31 PM Re: motor oil to use in summer and winter [Re: Nestor_Kelebay]
Davids Offline
And while some manufacturer's total filtration capabilities may be different than others, I submit to you that unless you're in an extremely dirty environment, and change your oil at least every 5,000 miles, you'll never come close to maxing out the filter's capacity.
OK, if that's the case, that brings us back to the question of whether or not the filter should be changed with every oil change. If the filter isn't anywhere near loaded to it's capacity, then wouldn't it be sensible to replace the filter on every 2nd or even 3rd oil change instead?
Everyone I know replaces the filter with each oil change, but I'm aware that car manufacturers used to recommend changing the filter every 2nd oil change. I don't know if that's still their recommendation.
this depends on how the vehicle is used. if you do alot of short trips (10-15 mins or less), or you drive frequently in dusty conditions (such as gravel roads) then your oil filter should be changed every time.
if you do mostly highway driving, and long trips, then your filter could last 2 oil changes.
now having said that, i dont really see why you wouldnt want to change it every time, its not like they are expensive or anything. most modern cars (90's and up) have a filter bypass. if your filter gets too dirty, then the oil will bypass the filter so it basically becomes useless. this is to prevent your oil pressure from going through the roof
#311510 - 09/20/06 07:29 PM Re: motor oil to use in summer and winter [Re: Nestor_Kelebay]
If you knew exactly how much contaminants you were introducing and was being captured by the filter, relative to the filter's capacity, you could calculate when the proper time was to change filters.
But this is a variable that you can't economically monitor/determine/control.
Hence - when you consider the cost of a filter, and the "old" oil that's generally trapped inside it if you were to just change the engine oil (no filter), it makes sense just to change the oil filter with each oil change.
All that being said, because the filter on one of my Harleys is so hard to get off/on, I only change it every other oil change...
#311511 - 09/20/06 07:47 PM Re: motor oil to use in summer and winter [Re: Davids]
Davids,
Great info for Nestor! But... How does this affect filter life? To my knowledge, short trips don't allow the moisture to evaporate out, but don't add particulates... What am I forgetting?
Al
#311512 - 09/21/06 09:05 AM Re: motor oil to use in summer and winter [Re: Davids]
MTeator Offline
"I am the Ipeman"
trust me, ive been to a few 8 hour "oil conferences", it was part of my paid training at jiffy lube. you learn alot listening to somebody talk about oil for 8 hours, lol
Davids, I don't mean this against you, but considering the quality of work at locations like Jiffy Lube either those conferences don't teach you anything, or the people there don't know how to learn anything.
I'll ask my ASE Master Tech brother the next time I see him. He's certainly gone to a lot more than a few 8 hour classes Between Volvo and ASE training, he's probably been to more school than me, and I have BS degrees in both math and computer science.
Btw, I've been told to always change the filter simply because it's full of oil... and you want that out too. Same reason to change the oil when the engine is warm/hot, so that more of it can drain.
Edited by MTeator (09/21/06 09:17 AM)
#311513 - 09/21/06 09:12 AM Re: motor oil to use in summer and winter [Re: MTeator]
Davids Offline
i am a licensed GM mechanic now, not a jiffy lube tech. i have alot more training than one 8 hour conference.
#311514 - 09/21/06 09:17 AM Re: motor oil to use in summer and winter [Re: Davids]
MTeator Offline
"I am the Ipeman"
I thought you were an electrician based off the tone of your posts in the electrical forum.
#311515 - 09/21/06 09:24 AM Re: motor oil to use in summer and winter [Re: MTeator]
Davids Offline
i have done electrical apprentice work, not FULLY licensed though
#311516 - 09/21/06 09:28 AM Re: motor oil to use in summer and winter [Re: Davids]
MTeator Offline
"I am the Ipeman"
From a quick google search:
5W30 versus 10W30
Virtually all new passenger vehicles sold in the U.S. use either 5W30 or 10W30 oil. The difference between the two is that the 5W30 flows better when cold, so if you live in a cold climate or operate your vehicle in a cold climate during the winter months, you should use 5W30 if it is the preferred oil for your vehicle. If you live in a sub-tropical climate and don't operate your vehicle in cold climates, then 10W30 is acceptable as long as the manufacturer specifies that it is permissible to use it.
Is there a disadvantage to using an oil that flows better when cold, i.e. 5W30 versus 10W30?
Sometimes, but usually not. The crux of the issue is this: the bigger the difference between the cold oil viscosity and the hot oil viscosity, the more the volume of viscosity modifiers and the less the volume of base stock. If you are good about following the manufacturer's recommended oil change interval then stick with the 5W30 if that is the preferred oil for your vehicle, even if 10W30 is acceptable in warmer climates. Older cars may specify 10W30 only. This is because they need a little more viscosity when cold to keep a protective film on the cylinder walls. There have been instances where the larger amount of viscosity modifiers that are present in 5W30 have broken down due to excessive heat and have left carbon deposits on the valves, but this is extremely rare. The proper fix would be to reduce the excessive heat, but the workaround was to use an oil with less viscosity modifiers.
I think I'll go with what the manual says, which is 10W-30. If 5W-30 was listed as the "preferred oil" then yeah, no brainer, use it. But in my case 10W-30 is listed as the "preferred oil".
#311517 - 09/21/06 10:15 AM Re: motor oil to use in summer and winter [Re: MTeator]
Nestor_Kelebay Offline
Specializing in Non-Fiction
MTeator: I guess it goes without saying that Winnipeg would normally be considered a "cold climate" during the winter months, so I guess I should stick with the 5W30. Also, that's what it says to use on my engine's dip stick.
But, I'm glad I looked into this so that I have confidence that what I'm doing is right.
Just that little bit of investigating I did leads me to believe that most people know precious little about the oil and oil filters they use in their cars.
If they did, there wouldn't be so many stores selling Fram oil filters and synthetic engine oil. I probably agree with Cabin Connection that you rarely ever come close to filling an oil filter with dirt, but in my books, if Fram is making filters that they know are inferior to the competition (albeit sufficient to our needs), buying their filters is helping to support them in that practice. I think they should all make smaller filtration capacity filters and charge less for them.
Also, from what I read, synthetic oil is really of little value if you drive a normal car at moderate speeds under normal operating conditions. The reason why is that the oil gets contaminated with products of combustion. Every oil will initially keep those products of combustion in suspension in the oil, but once the oil is saturated with them, further driving with that oil will result in them precipitating on the metal surfaces inside the engine. The resulting gunk on the inside of the engine is called "sludge". The whole point in changing the oil in a car is to replace the oil before it becomes saturated with that sludge, thereby keeping the inside of the engine clean. Synthetic engine oils are only a little better at holding sludge in suspension than regular oils, but cost substantially more than regular oil. That tells me that the cost/benefit ratio of using synthetic oil is lousy. It costs more, doesn't last much longer and really isn't needed under normal circumstances.
I believe if more people knew this, very few of them would buy synthetic engine oil. I think the problem is that people PRESUME that if it costs more, it's better. In this case, it's better for the company selling the synthetic oil because they make more money. It's not much better for you or your car.
But, I expect there's LOTS of examples of that, and this is only one.
#311518 - 09/21/06 10:33 AM Re: motor oil to use in summer and winter [Re: Nestor_Kelebay]
MTeator Offline
"I am the Ipeman"
I'd only use synthetic if the car calls for extended oil change intervals. One of my vehicles takes 10 quarts of synthetic, but I can go up to 15K miles between changes. 10 quarts of regular oil every 3,000 miles is more expensive than 10 quarts of synthetic every 15K miles (though I usually hit the time limit before the miles limit.)
