2 registered (dave, 1 invisible), 1 Guest and 0 Spiders online.
#215821 - 10/24/05 08:54 AM climatroll furnace problem only one burner lights
markn Offline
need some help on a climatrol furnace problem, the heater has three main burners, when the heater come on only the center burner will light and sounds like a jet air plane the other two burners will not light, when i turn it off and turn it back on then it will light all three burners, the gas preasure is correct and the controll vavle is working, could there be blockage in the the main burner supply tube or some part blockage in the orfices?
#215822 - 10/24/05 09:02 AM Re: climatroll furnace problem only one burner lig
HeatPro Offline
Loc: South New Jersey
That seems likely.
