0 registered (), 31 Guests and 1 Spider online.
#205644 - 09/20/05 08:13 PM 1996 beretta code failure
h2opsi Offline
Hello, I need some help in troubleshooting a code for the check engine light. the code is DTC P0118 and P1115. can you please steer me in the correct direction for repair
paul
#205645 - 09/21/05 05:14 AM Re: 1996 beretta code failure
If you are doing your own troubleshooting, a service manual is a must. It has the translation of the codes, and troubleshooting charts that assist in locating the bad component. Shotgunning the problem can get expensive, with no guarantee of actually finding the problem.
#205646 - 09/21/05 05:57 PM Re: 1996 beretta code failure
h2opsi Offline
thanks
#205647 - 09/22/05 05:15 AM Re: 1996 beretta code failure
Sorry I could not be of more help, codes are different on different models and makes.
#205648 - 09/24/05 06:26 PM Re: 1996 beretta code failure
woosha Offline
Loc: New Hampshire
p1115- Engine coolent temp signal from ecm to tcm.
po118-Engine coolent temp circuit high input.
Check you coolant temp sensor.
I would start there first.
woody
Lets make it a nice day!!!
#205649 - 09/25/05 04:53 PM Re: 1996 beretta code failure
h2opsi Offline
thanks
paul
