1 registered (1 invisible), 55 Guests and 2 Spiders online.
#202053 - 08/30/05 06:32 AM Thread Sealant Outdoot Box Wet Location
Lukus Offline
Loc: Ontario, Canada
Is teflon tape adequate for sealing threads for a box rated for wet locations? Its for PVC adapters (male pipe thread to socket), one connecting to a nonmetallic weatherproof box and another connecting to a metallic outlet box.
#202054 - 08/30/05 08:06 AM Re: Thread Sealant Outdoot Box Wet Location
3phase Offline
Really no need to worry about sealing the threads. They are OK as is. I have not had any leaks around the threads on a box. But since this is PVC conduit there are no worries about disrupting a ground connection since the PVC pipe does not ground the box like a metal conduit would. Use the tape if you want.
#202055 - 08/30/05 09:09 AM Re: Thread Sealant Outdoot Box Wet Location
Lukus Offline
I'll use it since it won't hurt and i have lots of teflon tape. The box itself says to use thread sealant.
Thanks 3phase
#202056 - 08/30/05 11:17 AM Re: Thread Sealant Outdoot Box Wet Location
dora Offline
Search and Rescue
Loc: Somewhere under the sun
Teflon tape is really only a thread lubricant and even though it can attribute to sealing, you don't want to have to depend on it to seal in a wet location. If this connection is for an outdoor electrical box then I would suggest you either use a connector that's approved for wet locations or apply a caulking to the threads before screwing them in.
