I have to replace a 4" cast iron pipe with its ABS counterpart, the cast iron soil pipe was elbowed by 3 sections with total 13 degrees turn( 3-5 degrees left turn per section, in order to keep the pipe running into the concret wall). The ABS elblows are only available at 22.5, 45, 60, and 90 degrees, how can I make a 13 degree turn? Can I just connect 3 sections of stright ABS pipe with an angle of 3-5 degree per section, and glue them with ABS cement? just like the guy did it with the iron cast pipe?
Thanks.
