#179059 - 05/04/05 09:46 PM Smell coming from breaker box
Wendell1964 Offline
Hello, I noticed today that I have a slight burning plastic smell coming from my breaker box. Is this normal during high load times. Is it time to call an electrician or am I just being paranoid?
#179060 - 05/04/05 10:56 PM Re: Smell coming from breaker box
Arnold Offline
Helpful Electrician
Loc: United States
Feel each of the breakers with your fingers. Are any of them hot?
I suspect a loose connection somewhere in your panel is creating heat that is melting some insulation. I would get this fixed soon. Chances are all that it takes is tightening a screw (and cutting away some damaged wire if necessary). It's simple, but working inside the panel can be dangerous so only a qualified person should open it up.
#179061 - 05/04/05 11:07 PM Re: Smell coming from breaker box
Wendell1964 Offline
I checked each breaker and none were hot but I am going to call in a professional to check it out. Thanks for the reply.
#179062 - 05/07/05 04:57 AM Re: Smell coming from breaker box
mtofell Offline
You are on the right track by calling in a pro... it sounds like a loose connection. This brings up a topic I have wondered about that maybe one of the pros can comment on. I once smelled the burning plastic smell you talk of and when feeling all of my switches found the culprit. It was on a thermostat for a baseboard heater and the whole thing was pretty much fried.... Anyhow, do the manufacturers of wire make the plastic sheathing so that it smells a lot when it burns or is that just lucky? The odor from mine was so strong that it smelled in the house for weeks after I fixed it. I have often wondered if this is on purpose or just lucky... I know any plastic smells pretty strong when burned....
Mtofell
#179063 - 05/07/05 05:05 PM Re: Smell coming from breaker box
3phase Offline
MTO, I think the stink from the wiring is just luck. I remember from old Firefighter training that all plastics do indeed give off noxious gases. I hate getting the wire smell on my nands, it lasts for days. A burnt out light ballast is even worse!
#179064 - 05/07/05 08:31 PM Re: Smell coming from breaker box
Wendell1964 Offline
I had a pro look at the breaker box and he found a few loose connections. He told me this is common because when there is a load on them they heat up and when the load is discontinued they cool off. The heating and cooling will, through time, cause the screws to loosen on the breaker.
