#178802 - 05/03/05 10:02 PM Culligan Water Softener E1 error
sholm Offline
Loc: Waconia, MN
Hello everyone. Browsed for months finally registered.
I got a Culligan Mark 100 water softener. Previous owners bypassed it. When I finally plugged it back in and un-bypassed(if that is even a word) and configured softener for the settings it said in the manual, I got the E1 message after the salt tank was filled up which is at the end of the regen cycle.
Called Culligan and another sevice CO with no answers but they want to stop out and look at it.
Any info on the error message and what I may or maynot be getting myself into.
Thanks in adv,
Scott
#178803 - 05/04/05 11:00 AM Re: Culligan Water Softener E1 error
Dennis_H_N.J. Offline
Loc: Toms River, N.J.
Try a manual "regen" then see what happens.. It may have to cycle thru!!
#178804 - 05/04/05 11:11 AM Re: Culligan Water Softener E1 error
sholm Offline
Loc: Waconia, MN
I do get this error on any regen cycle, weather I do it manually (holding in the Regen button for 5sec) or changing the regen time.
To clear, I have do a reset but it is reoccuring.
Thank you,
Scott
#178805 - 05/04/05 11:15 AM Re: Culligan Water Softener E1 error
Gary_Slusser Offline
Loc: Wherever I park the motorhome
In the back of most manuals are troubleshooting instructions and error code explanations. An error 01 should be fairly common, and Culligan could tell you what to check for if only they would... check out their web site for more info on error codes or troubleshooting, although they may not have them there.
Gary
Quality Water Associates
Gary Slusser 22 yrs in water treatment and well pumps, 13 yrs helping people on the 'net.
#178806 - 05/05/05 11:22 AM Re: Culligan Water Softener E1 error
pokey_da_man Offline
I also have a culligan water softener. I have had this problem on 2 occasions. 1st time it was an internal error and just unplugging for a few minutes re-set the softener and it worked fine. 2nd time a piston was stuck inside the head during the rinse cycle and I got the same error message. Culligan came out and fixed the problem......
#178807 - 05/05/05 01:50 PM Re: Culligan Water Softener E1 error
sholm Offline
Loc: Waconia, MN
Thank you for the information.
I will let you know how it turns out.
